DCS
It's time to sharpen the blades on the KK brush hog however, I have noticed there is a tack weld on the nut and bolt that is holding the blade on. Is this normal?
DCS said:It's time to sharpen the blades on the KK brush hog however, I have noticed there is a tack weld on the nut and bolt that is holding the blade on. Is this normal?
Farmwithjunk said:I wouldn't think so. But you needn't remove the blades to grind them. Most folks just block the mower up off the ground, making sure it's SAFE to work with your arms under it, then grind the edges of the blades with a 4-1/2" grinder.
Using a couple of chains, use your FEL to lift it on it's side. You will have plenty of room! Just make sure it is set so if the chains or the FEL fails it will fall away from you.DCS said:I thought about that, but it didn't look like there was enough room. I'll take another gander at it. Thanks.
