Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
  1. #21
    Elite Member
    Join Date
    Mar 2000
    Posts
    3,239
    Eastern Virginia
    EarthForce EF-5 mini-TLB (2001)
    Default Re: Cab pros and cons
    Andy - I thought about it when the idea of having a cab on my EF-5 first presented itself - thought about it a lot, in fact - but I don't think the extra 400 pounds makes too much difference in a total of 10,000. In fact, I can easily get more than that in liquid ballast, if I need to.
    But, I had forgotten to mention it as a con in my post, and I'm glad you didn't. As you say, it could be very significant on a smaller, lighter compact. Excellent safety point.
  2. #22
    Join Date
    Nov 2000
    Posts
    320
    Kubota L3710, JD5300, AC D19, IH 806, IH 8950, Ford 8N, Farmal Super M, several others in the past.
    I wonder if a cab is overall safer in a rollover than a ROPS? Body parts (arms and legs) are probably more likely to be injured with a ROPS than cab. Also, how many people always wear a set belt while operating their tractor? No seat belt with a rollover and ROPS is asking for serious trouble. No seat belt and rollover with cab - trouble but probably less.
  3. #23
    Elite Member
    Join Date
    Mar 2000
    Posts
    3,239
    Eastern Virginia
    radman - That's a good question - I've wondered the same thing. Some of the points you mentioned would seem to make a cab safer. On the other hand, I don't particularly like the idea of glass flying around. One of the biggest, though, is the one you mentioned: it would keep all your parts inside the structure, at least initially.
    Another factor, but not really related to your question, is that cabs are often FOPS (Falling Object Protection System) as well as ROPS, which is a big plus in my book.
  4. #24
    Elite Member Gatorboy's Avatar
    Join Date
    Aug 2001
    Posts
    3,106
    Bel Air, MD
    Kubota M8950, Bobcat 873 SSL & Kubota ZD-331
    Default Re: MChalkley 100,000th POST (I think)
    Mark,
    I believe your post (which I am replying to) was the 100,000th one!
  5. #25
    Join Date
    Aug 2001
    Posts
    3,106
    Bel Air, MD
    Yes Mark, I was correct. This was verified by Muhammad!
  6. #26
    Elite Member
    Join Date
    Mar 2000
    Posts
    3,239
    Eastern Virginia
    Yep, gatorboy, you were absolutely correct. It didn't occur to me to check that way. Of course, it was past my bedtime...
  7. #27
    Join Date
    Aug 2000
    Posts
    1,591
    Western Connecticut
    2003 Kubota L3430
    I like the feeling of being outside. In the heat. And in the snow. It feels natural, and part of the good earth. To me, a cab is an artificial environment, intolerably reminiscent of my intolerable office jobs, that filters out the sights, sounds, smells and windfeels of Mother Nature. Maybe I'd feel differently if I had to make my living on a tractor or if I lived in a more extreme climate zone.
  8. #28
    Elite Member
    Join Date
    Mar 2000
    Posts
    3,239
    Eastern Virginia
    glennmac - I used to agree with you, until I had the opportunity to plow snow and do other stuff in the cold and rain, with just a long-sleeve shirt on. Then, I was mighty glad to have it.
    By the time July gets here, I might be agreeing with you again... [img]/w3tcompact/icons/wink.gif[/img]
  9. #29
    Platinum Member hwp's Avatar
    Join Date
    Dec 2001
    Posts
    643
    St. Catharines, Ontario, CANADA
    Kubota F2400
    As Andy noted, the issues can be quite different between the big boys and the pretenders. From the attached you can see that I have a cab on my kubota F2400. It is only on for the winter. Once the snow stops, the cab comes off and I go with natural air conditioning. For snowblowing, the cab keeps the snow out of my face and the heat in the cab. When I am snowblowing, I am on relatively level ground and rollover is not a concern. However in the summer when I am mowing grass, I get onto some fairly steep sidehills, including ditches, and the weight of the cab would make the machine top heavy. But overall, I wouldn't be without a cab again.
    Attached Images Attached Images
  10. #30
    Join Date
    Nov 2000
    Posts
    858
    I bet your car is a convertible. [img]/w3tcompact/icons/wink.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
