Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Oct 2005
    Posts
    649
    PA
    NH TC40DA 2002
    Default 3-pt Spreader
    When using 3-pt spreader for fertilizer, what cleanup is required after use for the spreader and the tractor??
    2007 TC40DA, Supersteer, ANBO Grapple Rake with WR Long Joystick rocker control, Landpride 72" Box Scraper, 84" Rake, 72" Disc Harrow,72" Spring Tine Harrow, 72" Woods Rotary Cutter, Pallet Forks, 60 gallon Cropcare 3-pt sprayer, 72" 3-pt chain drag,Vicon 3-pt spreader
  2. #2
    Join Date
    Oct 2006
    Posts
    1,212
    Default Re: 3-pt Spreader
    spray it down
    get all that stuff off
    if you don't it rusts and corrodes the metal.
  3. #3
    Join Date
    Sep 2001
    Posts
    1,771
    Kansas
    Kubota L3000DT
    Plus, I think it helps to keep it inside.
    Meetings: If more than two people are there, at least one's time is being wasted.
  4. #4
    Join Date
    Oct 2006
    Posts
    1,212
    at the very least, cover it with a tarp
    and store it upside down (big end down)
    BTW, check out Herd Spreaders for truly great spreaders (a very satisfied customer)
  5. #5
    Join Date
    Sep 2001
    Posts
    1,771
    Kansas
    Kubota L3000DT
    Quote Originally Posted by LoneCowboy
    Me, too. My little M96 has done very well for me.
  6. #6
    Super Member Robert_in_NY's Avatar
    Join Date
    Aug 2001
    Posts
    8,543
    Silver Creek, NY
    Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
    How much do you plan on using this spreader? If you plan on using this a lot then look at Vicon. They make the best spreaders on the market and have poly tanks with stainless parts where any corrosion might want to start at. They will last a lifetime with proper care and are easy to use and clean as the poly tank pops off rather easily to let you get to the spreader gate so you can make sure it is cleaned and oiled well. The cheap metal units you see at TSC and other farm stores are nice units if you don't plan on using it much but you have to make sure you clean it as soon as you are done using it and oil the heck out of the thing or else it will rust up in no time. I see these things all the time that are rusted shut because they were not cleaned well enough. They are a fraction of the cost of the Vicon though but you get what you pay for.
    God must love stupid people; He made so many
  7. #7
    Join Date
    Sep 2004
    Posts
    583
    south/central Va.
    Deutz Fahr Agrofarm 100, Stoll loader, bucket, forks & root grapple
    Quote Originally Posted by Robert_in_NY
    I'll second that Robert. I have a neighbor that has used the same Vicon for 24 years now. On year 23 he had to replace the rubber damper, I'll call it that for lack of not knowing the proper name. He's averaged 20 tons per year of fertilizer spreading. I borrowed his once. Couldn't believe the spread pattern. It's the only spreader I've used that spreads the same distance on both sides.
    After I used his I bought one last year. I run 12 to 15 tons per year through mine and use it for seeding too. I had a Lely for 25 years and wore it out. I thought that was a good spreader until I used the Vicon. The Vicon is as close to perfect as any I've used. I also like not getting fertilizer all over the tractor too. I wish I'd bought one years ago now. No more green streaks in the fields.
    Charolais
  8. #8
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    I wash mine out with a hose for quite a bit. then I hit it with some wd-40 to displace the wather. then i lube it good.
    soundguy
  9. #9
    Super Member Farmwithjunk's Avatar
    Join Date
    Aug 2005
    Posts
    7,514
    Mt Washington, Kentucky
    Where do I begin.....
    VICON! I'd rather have ONE Vicon spreader than 20 of the cheaper ones. They last longer and are more accurate (consistant) with spread rate. It's not always just "which one is cheapest".
    There are three kinds of men;
    1.) The ones that learn by reading
    2.) The few who learn by observation
    3.) The rest of them have to pee on the electric fence for themselves.
  10. #10
    Join Date
    Oct 2005
    Posts
    649
    PA
    NH TC40DA 2002
    I've always been of the philosophy that you get what you pay for. That being said, the Vicon's are about 4x more spendy than many others. The concensus seems to be that they're worth the extra benjamins??
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
