Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jul 2007
    Posts
    4
    Default 861 Ford
    How do I remove the brake drum to replace a broken stud?
  2. #2
    New Member
    Join Date
    Jul 2007
    Posts
    4
    Default Re: 861 Ford
    I would like to know how to remove the brake drum so I can replace the broken studs to hold the wheel on.
  3. #3
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Art,
    It's pretty easy. The first thing is to take off the cover over the star adjuster and use a brake adjusting tool (or a wide flat blade screw driver) and loosen the adjuster a lot. If you do it with the rear end jacked up and resting on a stand you will have an easier time.
    When it is LOOSE, the wheel will spin easily. Take off the wheel. The drum should be removable. Use a soft face mallet or a block of wood and a hand maul to bap the back edge of the drum while turning it. If there is no movement at all, the drum may be rusted to the hub. A quick flash with an Ox/Ac torch and a rose bud tip on the drum, not the hub may be needed. You don't want to cook the axle seals.
    You can soak with PB blaster, or other penetrating oils. ATF and diesel works too.
    jb
  4. #4
    New Member
    Join Date
    Jul 2007
    Posts
    4
    How do I replace the studs that are broken off?
  5. #5
    Veteran Member BTDT's Avatar
    Join Date
    Sep 2006
    Posts
    2,208
    North Texas
    IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
    Welcome to TBN Art, here is a link to a New Holland dealer with a parts lookup, type your model # in the searchbox and see if you can get a diagram of the brake setup. Good luck.
    https://webparts.pvassociates.net/cnh/main.php
    Four Brothers Outdoor Power 2324 E I-30 Royse City Tx. 75189 Phone 972-636-2963 Fax 972-635-2363
    Praise is not something you do to get closer to God, praise is a response to God being close to you.
  6. #6
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,327
    Northwest, WA
    Hammer and a drive punch.
    ::Sent from a standard desktop keyboard::
    My Photobucket
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
