Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Gold Member
    Join Date
    Nov 2005
    Posts
    330
    Hannibal MO.
    4110 JD
    Default mower deck ate my bracket to 3pt hitch
    I have a 4110 J/D and last weekend a pin feel out of the linkage to the 3 pt hitch to the left arm of the deck, while going backwards the arm went under the deck. The photos shows wat is left of the turn buckle.
    Question. Can this be taken to a welding shop and fixed. Or am I better getting a new part at the tune of about 110 to 120 dollars.
    It seem it is about 3/8 or so very strong steel, I think.
    Any welder out there that can give me some advise.
    Thank for any help or ideas. Oh I already know do not do that.
    Roger
    Attached Images Attached Images
  2. #2
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Default Re: mower deck ate my bracket to 3pt hitch
    Rats! You cancelled out my best advice!
    But seriously, a welder can fix anything made of metal. It's just a matter of cost. On your part, it needs to have the old stuff taken off, then a new strap with slot milled ($) then that strap welded on. I'm assuming you would want the whole deal pounded out flat too. I'd guess your looking at a shop charge of around 2 hours. That means the repair cost is about the same as or a little more than, the replacement cost. Your call. I'd buy a new one and keep the old one around to remind me. Also, you never know when you may find a use for it.
    jb
  3. #3
    Gold Member
    Join Date
    Jun 2006
    Posts
    330
    NW WA State
    1980 AC 5020
    Quote Originally Posted by roermo
    Roger
    I've done some welding, but don't consider myself a welder. That said, that part could be welded up. Break it off, flatten it out, weld it up. 2 ways to do the weld, either grind a full depth bevel for a full penetration weld from the outside, or put a small bit of steel over the break on the outside and weld that up. The small bit gives more edges to weld. If it doesn't carry lots of weight the bevel and weld might do it. I'd think you'd want someone with a TIG machine because it's a pretty small part.
    Monte
    2007 NH TC30 w/FEL, 6' box blade, 6' back blade, 6' Mott F6 flail mower, 6' chain harrow, 6' rock rake, Pat's Easy Change, looking for a 6' snow blower
  4. #4
    Platinum Member Grrrr's Avatar
    Join Date
    Jul 2007
    Posts
    800
    Devon, UK
    John Deere!
    I think by the time that you take it into a shop and they fix it up for you, you would be better just to buy a new one.
    Just my thought
    Jake
  5. #5
    Gold Member
    Join Date
    Nov 2005
    Posts
    330
    Hannibal MO.
    4110 JD
    Thanks all,
    John Bud ,sorry I stole your line, but it reminded me of the person that goes into the doctor's office and say it hurts when I do that, the doctor said don't do that. $50 dollars please.
    I think you might all be on to something, a new part and forget it. I think I would always be worried if the fixed one would hold out. And if it is about the same amount of money why take that road.
    Thanks all
  6. #6
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,108
    Peoria IL
    New holland TC(33)
    this is were it pays to have a buddy/neighbor with a welder.
    My friend i car pool with broke a mount on his car seat. Would have ment a major headache. instead it was 3 mins to pull the seat out and walk it down to my neighbor that was out and he wipped out his tig and good as new
    break it off, weld it back on for free.
    if it doenst hold, your not out any $$ and you can still buy the new part.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  7. #7
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    This looks like a good time to buy that welder that you always wanted.
  8. #8
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Quote Originally Posted by JerryG
    Hmmmm let's see now,
    1) Pay someone 100 bucks to fix this one
    2) Buy a new one for 110-120 bucks
    3) Buy a 250 amp ad/dc stick, mig & Tig combo welder for 2500 bucks + 1200 bucks for sticks, mig wire, tig tips, gas cylinders, autodarkening helmet and a supply of steel to learn how to weld on.
    Yup, option #3!
    Good call JerryG!
  9. #9
    Gold Member beersngars's Avatar
    Join Date
    Jul 2007
    Posts
    429
    Ohio
    Kubota L3400HSD
    Quote Originally Posted by john_bud
    Yup, option #3!
    Good call JerryG!
    Yep..Usually the way I do that kind of thing. After all it's a TOOL.
  10. #10
    Gold Member
    Join Date
    Nov 2005
    Posts
    330
    Hannibal MO.
    4110 JD
    The last two posts are a good thoughts, can I give the cost list to my wife and qoute you guys as gosple. Sounds like a plan. But you all forgot the cost of the schooling and maybe one or two trips to the Emergency with burns cuts and the like. Hum. (thinking)
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
