Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Jul 2007
    Posts
    3
    Default Kill switch
    Hello there.
    I just bought a used 3010s new holland. The guy that sold me the tractor, told me the kill switch is bad, and to shut the engine will have to put it in gear and high throttle and hold the brake. It works. He did not know where the switch is located on the tractor. I went to my local new Holland dealer , they could not help me . Bought new ignition switch , did not help either.
    Does anyone out there knows where the switch is? I would really appreciate some help on this. I am also looking to buy a repair manual, if any one has one for sale.
    Thanks
  2. #2
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    Default Re: Kill switch
    Not familiar with that tractor. but is it a diesel ? If so you have to shut off the fuel to kill it. There should be some method to do this on the injector pump.
  3. #3
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    The "kill switch" on a diesel is usually either the throttle linkage itself or an electric solenoid on the injector pump. The purpose of both is to cut off the fuel flow. I am not familiar with your tractor, but if the former owner said the "kill switch is bad," I vote that there is an electric solenoid on the pump and perhaps that is bad.
    If there is a solenoid you should be able to hear it "click" when you turn the key to the "run" position. if not maybe it is stuck. Usually they go bad in the off position and you cannot get the tractor started.
    Anyway, look for an electrical connection to the fuel injector pump.
    Mike
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  4. #4
    Member
    Join Date
    May 2007
    Posts
    34
    Texas
    John Deere 950
    On my JD you pull the throttle back to kill it. But that's JD, not sure on your NH.
  5. #5
    Gold Member
    Join Date
    Jan 2007
    Posts
    377
    Ky
    TC55DA
    Look on the NH web site and under parts you can look up your tractor as a break down of parts if that helps.
    TC55DA 270TL ,Harley rake,Grader box ect ect ect
  6. #6
    Join Date
    Apr 2007
    Posts
    174
    NW Georgia
    1964 Ford 2000D and 1960 Ford 801
    Here is the page from the NH website that shows your pump. Item number 3 is the electric solenoid for the fuel shut off. Part number is 9986316.
    I circled the solenoid in red.
    Older versions of this pump used a manual kill cable attached to the pump. The blue circle to the left of the pic was the kill lever on the older pumps. The other blue circle is the throttle arm. If your pump has the kill lever on it, you could connect a cable to it to shut your tractor down. You could check it first by connecting a piece of wire to it that will reach the seat (don't stand beside it with it running ). Start the tractor up then pull the wire to see if it kills the engine.
    Even after replacing the electric cut off, a cable could serve as a manual cut off in case the electric one fails again.
    Mike
    Attached Images Attached Images
  7. #7
    New Member
    Join Date
    Jul 2007
    Posts
    3
    [QUOTE=MikesTractor]Here is the page from the NH website that shows your pump. Item number 3 is the electric solenoid for the fuel shut off. Part number is 9986316.
  8. #8
    New Member
    Join Date
    Jul 2007
    Posts
    3
    Thank you all for your responce. Will try it this weekend.
  9. #9
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,124
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Wow...the guy you bought it from is a real piece of work... It's not hard to replace the fuel shutoff solenoid on these 10 series tractors.. I was checking mine out just today after reading a post about a failed one on jinmans tractor.
    And i hope you meant high gear and low throttle... still.. what a horrible thing to do.. lug the engine down... Please pos t the sn on that tractor... I've bene wanting to get a 3010s as a medium sized tractor.. but surely don't ever want to run into that one down the road. ( grin)
    What is evenmore surprising is that your dealer was clueless about the part... you don't perchance live anywhere near LoneCowboy do ya (wink)
    good luck on the repair.. you will enjoy it much better with key-off ability..
    Soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
