Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Feb 2007
    Posts
    1
    Default 580 B fuel tank removal
    Have a Case 580b trying to remove the fuel tank.
    Problem: Tube between the uprights. This blocks removal of the tank.
    Have removed rod treaded on both ends that passes through the uprights and the tubes.
    Have removed the two pins that hold the loaders arms and go into the uprights. Still not able to remove tube. Have you been successful in removing tube and fuel tank?
    Thanks
    Bill
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    D7E
    D7E is offline
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    1,949
    manitoba
    Many
    Default Re: 580 B fuel tank removal
    Quote Originally Posted by wjpedersen
    Thanks
    Bill
    I did an inframe engine job on mine last winter and i know i took the tank off but can't remember how but i don't remember it being that hard , Maybe i had taken some other junk from around it first ,I'll have another look ?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
