12-22-2007, 07:51 PM
#11 (permalink)
| | Platinum Member
| Re: Kubota B21 TLB complete driveline rebuild DAVE: When you get that industrial strength TLB back together; it should draw a lot of attention, if you trailer it anywhere with that 4n1 bucket? If you ever decide to sell it, it may draw a ransom price also!?
My adjacent neighbor has had one for several years, and I am amazed at it's capability....no 4n1 bucket however! Which I think is very rare too?
I have the B21's big brother the L35, and also have the 1/8" (boiler plate on the hood),... small rocks, etc. just bounce off! I like the manueverability of this generation of Kubotas, and their strength/ability to work in confined quarters. I still think Kubota should have painted them yellow?
You are making good progress on the rebuild, and enjoy the progress reports/photos too!
LEE |
12-23-2007, 08:14 PM
#12 (permalink)
| | Veteran Member
| Re: Kubota B21 TLB complete driveline rebuild Quote: |
Originally Posted by EddieWalker I doubt this will help, but when the transmission went out on my jeep, I pulled it out to have it rebuilt, and found out that it was cheaper to just buy a brand new one to replace the old one. Faster too!!
| But, Eddie, half the fun is doing it yourself! And, since I work for "free"
on my own stuff, I am way ahead on costs.
Thanks
__________________ See my TBN projects at: http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!) |
12-23-2007, 08:20 PM
#13 (permalink)
| | Veteran Member
Originally Posted by machmeter62 I have the B21's big brother the L35, and also have the 1/8" (boiler plate on the hood),... small rocks, etc. just bounce off! I like the manueverability of this generation of Kubotas, and their strength/ability to work in confined quarters. I still think Kubota should have painted them yellow? | Thx, Lee.
One of the reasons I got this machine is I wanted to see first hand what
some of the differences are betw regular CUTs and industrial CUTs.
Not only do I see 1/8" plate on the cowl, but also excellent undercarriage
armor, a throttle that is accessible while working the hoe, a complex
seat rotation mechanism, fairly hi hyd flow, triple filtration of hyd oil, etc.
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
12-24-2007, 12:31 AM
#14 (permalink)
| | Veteran Member
| Re: Kubota B21 TLB complete driveline rebuild OK, now for the fun part.
One of the reasons I was interested in this tractor is to take apart
a modern HST. The good news here is that the HST is OK, and needs
nothing. There is a separate filter for the HST, which protected it from
the puree of broken metal fragments that came out of the main gearbox
and rear end.
First photo shows the main components of the HST. The motor and the
pump are virtually identical. The pump varies its displacement with
a variable angle swash plate. The motor uses a fixed swash plate.
The tube with the O-rings in the middle is where the MFWD drive shaft
passes thru the HST on its way to the main gearbox. Oil in the HST
does not mix with that in the gearboxes until after filtration. Nice.
2nd photo shows the cylinder block and pistons. Note the hole in the
brass "slipper", that rubs against the swash plate. That supplied lube
to the plate, and, of course, contributes to some of the inefficiencies
of a HST.
Finally, I miked everything and nothing was out of spec. One bit of
good news. I replaced the main shaft ball bearings anyway (they are
cheap).
Next: charge pump and main gearbox
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
12-26-2007, 09:59 PM
#15 (permalink)
| | Platinum Member
and rear end.
of a HST.
cheap).
Next: charge pump and main gearbox | DAVE: I really enjoy your posts and pictures of the inter-workings of that B21. It is beyond my skill level, and too many parts would be leftover!
My skill level was challenged with my first car, a '40 Chev. coupe, which had a vacuum shift for synchronizing the gears, which was soon inoperative! I had to learn to "double clutch" it, that often got the attention of pedestrians, with verbal comments of "grind me a few pounds" till I found the solution!
LEE |
12-26-2007, 10:49 PM
#16 (permalink)
| | Veteran Member
| Re: Kubota B21 TLB complete driveline rebuild This post gets into the charge pump, which supplies hyd fluid to the suction
side of the HST pump, and the implement pump.
The charge pump (first pic) is mounted to the front of the HST and is always
driven at engine speed by the drive shaft, even when the HST has no demand
(foot off the go pedal). This takes up a few hp, further sapping some of the
engine power seen by the PTO, even when the tractor is not moving. Looking
at the pump, I saw scoring of the aluminum case, and the steel rotary gears.
This can be attributed to the fact that this pump draws oil from the reservoir thru
a steel mesh screen, which did not completely exclude the metal particles that
got into the oil from the disintegrated main gearbox. The charge pump only
operates at a couple hundred psi, and this one may suffice, but I was not
comfortable re-using it. Another $300 for a new pump.
The second pic is a little blurry, but it shows the implement pump, which I
opened up to check. It is in fine condition, thanks to good filtration. The
diverter valve sends oil to the power steering valve, and excess oil (when not
steering) supplements the flow from the charge pump to the HST. The HST's
oil from the charge pump is filtered again, explaining the lack of damage to the HST. In the past with older cars, I liked to open up the engine oil pumps to
check for scoring, which gave me some indication of how well the previous
owner(s) cared for the car.
Next: look, Ma, no gears!
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
12-26-2007, 11:25 PM
#17 (permalink)
| | Platinum Member
| Re: Kubota B21 TLB complete driveline rebuild interesting project, i look forward to the progress.
Shane |
12-27-2007, 10:36 PM
#18 (permalink)
| | Veteran Member
| Re: Kubota B21 TLB complete driveline rebuild Here is the main gearbox just after I separated it from the HST, and
the rear diff housing. Nothing inside but one gear, one shaft, and one of
the 4 shifter forks!
2nd photo is the inside of the diff housing. Pinion gear and shaft are
missing, but the damaged ring gear is in there.
3rd photo shows some of the loose broken pieces I found. The circlip
and steel casting fragment were inside the hyd oil reservoir, also in the
picture. The new steel casting forms a bearing and shaft support
inside the gearbox. Some huge forces shattered the original. Most
interesting was the crushed spring, which came from the MFWD shifter
detent. I found it at the bottom of the diff housing, behind the largest
axle gear. I think it got crushed between the ring and pinion gears, shattering
their teeth. If so, what caused the spring to come out? Perhaps a
broken shifter fork, as that one is only aluminum, and the operator could
have forced it.
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
12-28-2007, 03:31 AM
#19 (permalink)
| | New Member
| Re: Kubota B21 TLB complete driveline rebuild Dave,
Been there done that. Looks like you are making good progress on the rebuild.
It is interesting to note that we are both in Norcal (I am in Ovale), too bad our B21's didn't break down around the same time.. Could have compared notes.
So far my b21 is running solid after the rear-diff rebuild (about 60 hours).
Just make sure you get the HST pedal return spring on before you put it all back together (I forgot and had it all back together before realizing).
Cheers -Lucas |
12-28-2007, 02:02 PM
#20 (permalink)
| | Veteran Member
Originally Posted by yubby Been there done that. Looks like you are making good progress on the rebuild.
Just make sure you get the HST pedal return spring on before you put it all back together (I forgot and had it all back together before realizing). | Hey Lucas....
I missed your B21 thread the first time around, but I read it all as soon as
MACHMETER pointed it out. I am glad nothing has broken since.
It is true that there were some assembly order issues for me as I did not
take the tractor apart first. I had some trouble with the HST pedal spring,
but not the one you had. I had to fabricate the part on the HST casting
as it was one of my missing parts. I DID make the mistake of putting the
2 halves of the tractor together before attaching the top hyd hard line to the
charge pump. This would not have happened if I had taken the tractor
apart myself.
Were your ROPS/ FOPS support bolts on the rear axle as bad as mine?
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
