Page 202 of 856 FirstFirst ... 102152192199200201202203204205212252302702 ... LastLast
Results 2,011 to 2,020 of 8553
  1. #2011
    Elite Member Skyco's Avatar
    Join Date
    Jul 2007
    Posts
    2,718
    SC/NC
    Default Re: Harbor Freight Tools that don't suck
    Bought the HF 46 Piece Bolt Puller Set on sale for $9.99 to pull the harmonic balancer on my 7.3 Powerstroke.
    Worked great although I was fearing I'd Dargo it.
    BTW anyone contemplating switching the OEM harmonic balancer for a FluidDampr should do it! Amazing difference in engine smoothness
    Attached Thumbnails Attached Thumbnails Harbor Freight Tools that don't suck-image_497-jpg
  2. #2012
    Super Member
    Join Date
    Dec 2007
    Posts
    9,877
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Has anyone seen or used their "18 lb Vibratory Cleaner"?
    18 Lb. Vibratory Bowl w/ Liquid Drain Hose
    It is against my solemn pledge to never buy anything with a motor from HF but this looks tempting, especially when on sale. I have seen smaller tumblers with various medias such as walnut shells, corn cobs or wharever do a remarkable job on cleaning and polishing small parts. The reviews look tempting but it would be nice to find a TBNer that knows about them.
    It has a "liquid drain hose" but I would never use a liquid.
    May I be the kind of person my dogs think I am,
  3. #2013
    Super Member California's Avatar
    Join Date
    Jan 2004
    Posts
    9,595
    Sonoma County
    Yanmar YM240, and now just one YM186D
    I bought HF's smaller $40 tumbler. It works as expected. (Whoa! $99 now!)
    I processed nuts, bolts, washers to remove minor rust. They cleaned up ok but this created a fine powder of rust-dust in the air that gagged me and I think it would clog your lungs. Adding water prevented this. The powder rinsed off as mud.
    Attachment 226427
    The tumbler walked all over so I set it in a small automotive wheel.
    The noise was annoying and the batches took longer than I expected. I now close the door to the shop and stay away at least 20 minutes.
    I had a couple hundred pounds of nuts, bolts, washers with minor rust. This made them usable. For example the wheel weights I installed last weekend use washers and double-nuts from those batches. (I had the 10" bolts too, but cleaned them with a wire brush). This saved me a drive to the hardware store and a few dollars.
    The tumbler has more than paid for itself by now.
    Added: Buy the warranty. HF's Customer Reviews say these fail frequently.
  4. #2014
    Member leeinMT's Avatar
    Join Date
    Feb 2010
    Posts
    41
    Montana
    Kubota L295DT
    Re: drill presses. I bought a 2 hp mill drill from Wholesale Tool about 14 years ago for about $1100 and have had no regrets. Zero play in the spindle and can precision drill anything from 1/32 to big holes. I use it almost daily and have learned not to skimp on the drill bits - best to go with cobalt. Wholesale Tool still has this thing for what I paid.
    Like some of the folks here, I am hesitant to buy anything from HF that you have to plug in.
    Drill Doctor is another good investment.
    Attached Thumbnails Attached Thumbnails Harbor Freight Tools that don't suck-mill-drill-jpg
    It's always about food.
  5. #2015
    Super Member 5030's Avatar
    Join Date
    Feb 2003
    Posts
    6,000
    Michigan, S.E. Monroe County
    Kubota M9000 Hyd Kubota M105 shuttle
    I was given a drill doctor for Christmas and gave it away. I much rather offhand sharpen all my twist drills, both split point and parabolic.
    Drill Doctor takes too much time and learning to offhand sharpen drills becomes an acquired skill that you'll never forget once you master it.
    A couple Kubota's and some payment books.....
    "If haying was easy, everyone would do it. It isn't."
  6. #2016
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,011
    Washington
    B7100
    I mail packages occasionally for stuff I sell on EBay and wanted a new scale. I bought this one, # 95364
    Digital Scale
    I checked the accuracy with a few combinations of coins and it seems accurate to a gram or less, at least for small stuff. Total capacity is 11 pounds. With 20% off, it was about $12. Operates on 4 AA batteries and comes with an AC adapter.
    I also have the very small scale, 97820, and have been very impressed with the quality - great for weighing envelopes and food for cooking, etc.
    Attached Thumbnails Attached Thumbnails Harbor Freight Tools that don't suck-scale-jpg
  7. #2017
    Silver Member rbstern's Avatar
    Join Date
    May 2011
    Posts
    203
    GA
    Yanmar 2210
    Quote Originally Posted by Travelover View Post
    Digital Scale
    Have it and think it's great.
  8. #2018
    Join Date
    Jun 2010
    Posts
    701
    north Mississippi
    NH 3040
    the big 3/4 drive set is holding up pretty good for 50 bucks. if I buy 4 sets in a lifetime I'm still better off unless it hurts me. lol
    NH 3040 fel 6' cutter
    JD 737 zero turn
    polaris ranger xp
    99 honda 300
    Trek Emonda SL8.
  9. #2019
    Silver Member evan price's Avatar
    Join Date
    May 2011
    Posts
    129
    Radnor, Ohio
    Satoh S470 Buck
    Their replacement vibratory polisher bowls fit a Midway 1292 perfectly. I tumble a lot of brass and I've worn out four bowls so far.
    Sic Gorgiamus Allos Subjectatos Nunc
    Woods Equipment Co. - FREE online download of manuals:
    http://www.woodsonline.com/manuals.aspx
  10. #2020
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    Mine are good also. They double as shims when I press bearing out. So they have been worth it. I still expect the ratchet to snap. There is alot of play to them , But maybe that is normal given the size..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
