Page 314 of 838 FirstFirst ... 214264304311312313314315316317324364414814 ... LastLast
Results 3,131 to 3,140 of 8377
  1. #3131
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    Default Re: Harbor Freight Tools that don't suck
    Quote Originally Posted by daugen View Post
    Agreed. For seventy bucks, I'm not ruining my good woodworking saw. Thanks
    3-1/2 HP 14" Industrial Cut-Off Saw
    they make a higher hp one also. Think that's worth thirty bucks more?
    wonder if it's 220, how do they get 3 1/2 hp on 120?
    as I posted before I have bought thousands of harbor freight tool store returns and I have seen many of the cheaper cut off saws but never one of the 3 1/2 hp ones if that helps .if it were me I'd just buy the better one and always buy the extended warranty on electric power tools , I use a machine buffer quite often and with the warranty they have replaced it 3 times with little extra cost I put the recipt in the box and date the outside of the box so I can make sure it's running right before the warranty expires , I know a few guys who buy the 220 aircompressors with the warranty and use them for a year and then return them and get a brand new one every year .
  2. #3132
    Super Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    9,689
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    Horsepower is terribly overstated!
    Horsepower is more like 2.2 at 90% conversion efficiency. Remember 746 electrical watts = 1 HP @ 100% conversion efficiency. Isn't the false HP statement a violation of some Federal Law?
    Now I don't feel so crazy... this is a post on the reviews of the larger saw, which btw were almost totally positive.
  3. #3133
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    There were lawsuits against most small engine manufacturers years ago over stated hp vs actual hp thats why all the engines you see now are listed as cc's and not hp
  4. #3134
    Join Date
    Feb 2012
    Posts
    9,689
    Quote Originally Posted by Grumpy Old Man View Post
    Agreed. Because these are electric motors, I though UL or whatever had this straightened out a long time ago...
    From what I've seen on table saws, going over 3hp usually means a 220 motor or that 120 power source had better be a full 20amps.
    And this one said it was 15. Just doesn't compute.
  5. #3135
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,103
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Darn right. And these are brush universal type motors ... notoriously inefficient. With a good single phase induction motor you can get 3HP output on 120VAC, 20A. These brush motors are either rated as 3HP input ... or peak output as you blow the 20A breaker. ??? Are these variable or single speed setups ... anybody know?
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  6. #3136
    Join Date
    Feb 2012
    Posts
    9,689
    single, but can be varied by pulley to a different set speed
  7. #3137
    Silver Member ditzel's Avatar
    Join Date
    Mar 2007
    Posts
    192
    N.J.
    Mahindra 2615 Gear
    Central Hydraulic Log Splitter, about 10 years old, it sat not used for the last 5 years. Only problem was both tires went flat and bead broke, took care of that with some ether and a lighter. It has the briggs engine, with fresh gas, turned on fuel switch, started after a couple pulls, runs like a champ. I think I paid about $600 for it new about 10 years ago, got to say it was worth every penny, has split every log I could load into it.Harbor Freight Tools that don't suck-imag0064-jpg
    _____________________________________________
    Mahindra 2615gear,Homemade QA,Pallet Forks,Rear Pallet Forks, WoodsBH,Boxblade,Yorkrake,Rearblade
  8. #3138
    Join Date
    Feb 2012
    Posts
    9,689
    Quote Originally Posted by ditzel View Post
    Nice picture of your wood splitting operation. Looks like you had a lot of trees blown down too, so you'll keep busy now.
    Those Briggs engines don't get a lot of respect, but boy, I have the 1650 on my TSC/Huskee splitter and the engine is a serious good starter like yours.
    Even in really cold weather, it starts right up. I use synthetic oil and only run it at half to three quarters speed, plenty of power, so I hope it lasts a long time.
    I'm looking closer at your splitter, and that's built sturdily for a 600 dollar splitter.
    As I've said before, the Chinese do well with iron and steel.
  9. #3139
    Veteran Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
    Quote Originally Posted by Gary Fowler View Post
    That looks just like the Craftsman that I paid $189 for several years back. Maybe made in the same Chinese factory.
    I don't like the orientation of the handle on this saw. If you are using it on a bench then it will be difficult to control. If using it on the floor it would be OK. A saw with the handle grip horizontal would be easier on the wrist. One or two cuts a day you wouldn't feel it, but if you were using it all day long you would.
  10. #3140
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    Quote Originally Posted by sparc View Post
    sounds like you need to excercise a little more if you can't run a saw more than a couple times a day ,
    last week I bought one of these Dewalt saws at a local pawn shop for $100.00 easily replaceable brushes and like new condition , never ceases to amaze me why people won;t use pawn shops to buy equipment Harbor Freight Tools that don't suck-51y-jihwmpl-_aa300_-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
