Page 340 of 897 FirstFirst ... 240290330337338339340341342343350390440840 ... LastLast
Results 3,391 to 3,400 of 8964
  1. #3391
    Platinum Member NHmitch's Avatar
    Join Date
    Mar 2012
    Posts
    933
    SW New Hampshire
    Bolens G154/IsekiTX1300F
    Default Re: Harbor Freight Tools that don't suck
    Thank you so much for the offer!
    I actually had broken down and bought the stake sides two days ago, before I saw your post, and I really appreciate the offer! I ended up using a 20% off coupon, so they weren't too bad. Did they seem to be about the same quality as the rest of the trailer? Thanks again, and I hope that you guys are having a great spring
    Quote Originally Posted by California View Post
    I have the metal stake/sides kit (3 sides, tailgate missing) that came with this trailer. I'll sell it cheap, but I doubt cross country shipping is worth your trouble. I'll post a photo if anyone cares.
    Mitch
  2. #3392
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,005
    Northern Vermont
    Kubota, Case, Deere
    If you don't need the fenders you can remove them and replace the wheels with 12" ones. It'll help it roll over roots and rocks. Or if you know anyone with a golf cart who has some old wheels/ tires most of them are the same bolt pattern and are much wider to help keep from sinking into the mud (if you have any).
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  3. #3393
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,038
    Washington
    B7100
    One tool that definitely sucks is the 25 foot tape measure that they give away free with a coupon. I used one yesterday for the first time and it pulled out and that it was it - no recoil. I was replacing another one that did the same thing after just a few uses. I took it apart to see if there was a simple fix, but I realized that I had a couple new ones still on a shelf, so I tossed it in the garbage.
  4. #3394
    Join Date
    Mar 2012
    Posts
    933
    SW New Hampshire
    Thats great to know! Thanks for the info! THat may be a good option, since when I packed the hubs with grease, I put in too much, and the seals came out the back. I was able to put them back, but not sure if they will hold. I do plan on using this maining in the woods, to collect firewood that I have cut, so that would work out great.
    Quote Originally Posted by crazyal View Post
    Mitch
  5. #3395
    Super Star Member California's Avatar
    Join Date
    Jan 2004
    Posts
    10,018
    Sonoma County
    Yanmar YM240, and now just one YM186D
    Quote Originally Posted by NHmitch View Post
    With no brakes, the grease seals aren't very important. Of course its better to keep water out but flinging grease is harmless.
    The bolt pattern is 'standard US boat trailer 4-lug' so many alternate wheels should fit. I think Vega or some other early US subcompact also had 13 inch tires on that bolt pattern. But side clearance may be an issue for any oversize tire.
  6. #3396
    Join Date
    Jan 2004
    Posts
    10,018
    Sonoma County
    ... stake sides ... seem to be about the same quality as the rest of the trailer?
    Let's say the sides look to be sufficient quality to use on an ultralight trailer.
    Harbor Freight Tools that don't suck-p1650286rhf40x48trailer-jpg
    I wanted higher higher, dust-resistant sides for that other 'jeep trailer' in a prior post so I ripped a sheet of 1/4" plywood to something like 22" / 26". This made sides that rested on the deck, and a front panel that bolted to the front face of the chassis for rigidity. Four aluminum channels bolted outside the chassis held the front/back edges of the side panels. That little trailer is so light that I can lift the back and move it sideways carrying the usual lightweight folding chairs, sleeping bags, etc on a camping trip. (And this is sometimes necessary because these ultra-short-wheelbase trailers are hard to back up, and hard to see looking back from an SUV because they are so narrow).
  7. #3397
    Bronze Member graydog111's Avatar
    Join Date
    Mar 2012
    Posts
    95
    Mustang, OK
    5 Gravelys, 1963 4010 & 1950 B John Deere, Great Dane ZTR
    Another use for trailer:
    Harbor Freight Tools that don't suck-att1-jpg
  8. #3398
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,112
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Quote Originally Posted by graydog111 View Post
    Now that is clever.
    May I be the kind of person my dogs think I am,
  9. #3399
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,038
    Washington
    B7100
    That is just teats.
  10. #3400
    Elite Member
    Join Date
    Sep 2002
    Posts
    3,038
    Washington
    B7100
    That is just teats.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
