I actually have the 79cc gas HF water pump, and it is an incredible pump.
http://www.harborfreight.com/clear-water-pump-with-79cc-ohv-gas-engine-69747.html#.Uy8kXa1dUzI
The reviews are misleading, because the majority of negative reviews are only because HF does not carry the 1" drain, or suction hose, but there is a very easy solution for this. I bought the pump to drain a very large well, that easily equals the quantity of a large above ground pool. I needed to do repairs to the sides of the well in our pasture, and I have used the pump to drain that well multiple times, and as a fire pump, when I had large brush piles I had to burn. I did buy 200" of 1.5" fire hose and a fire nozzle, and it easily spray a large quantity of water 30-40".
As far as the pump goes, it always starts on the first pull, and runs very smoothly, and I did a bit of research on this pump, and a few people who had used both pumps, said that this pump outperforms the 2" pump. I can only attest to this pump, but I was able to completely drain my well, in about an hour, and I may have been able to it faster, but The well is about 35"deep, so there was a stronger draw required.
As far as the hose is concerned, I bought 1" fish pond hose from home depot, and I use it as a suction hose, and it can be easily used as a drain hose. It never collapses from the pressure of the draw, and the it was only $20 for a 20ft section.
Total Pond 1 in. Corrugated Tubing-C16020 at The Home Depot
If you only need to do this once, then you may want to rent a pump, but I highly recommend the pump, and they usually have it on sale, and with 20% off coupons, you can usually get it for around $100. This pump is actually one of my favorite small engine tools to use because it works so well! It also comes with the suction strainer, and the clamps. I added quick connect couplers to it, and they make it faster to use when you have to move it around, and they were under $10 at Tractor Supply. Hope this helps a bit!
This is the pump:
This is the hose that I bought:
I need to drain a fairly large in ground pool to abandon it and fill. I'm considering buying a HF pump vs renting on. Daily rental on a 3/4" 120v sump is $21/D and $66/W. HF has #69299 3/4" sump for $59.99. They also have #69747 1.5 hp gas 1" for $149.99. I'm not 100% sure I can do what I need in a single day, so I'm considering buying. Anyone have experience with either pump. I read reviews but they mostly involved using them as a constant water pump for water features or large aquariums, where I really probably need to pump 4-12 hours per day for at most 2 or 3 days. Any thoughts?
