#1 (permalink) |
I didnt want to hijack the other air thread, but I was wondering how many of y'all have the compressor and tank mounted outside, and fittings plumbed all around the garage? I helped a buddy install his a few years ago. We used pvc pipe and it works fine, no noise to listen to. And no heat being generated in the A/C'd garage.
#2 (permalink) |
If I'm painting I roll the compressor outside so it can breath and be cool. Normally heat is a good thing in my garage.
__________________
Steve The best things in life are not things. |
#3 (permalink) |
Gold Member
I plan on plumbing my new garage for compressed air ports all around. Winters in Maine are too cold, snowy, icy to put the compressor outside. I was planning on using PVC rather than copper, I just might use the sch 80 for strength near the connectors.
__________________
Jim - Husky W4814- 48" walk behind lawn mower. For my 1.7 acres of lawn. - '06 Kioti CK30 HST - KL130 loader w/reinforcing bracket, SS QA, LK3054 QA bucket, engine coolant heater, dual rear remotes, KB2375 Backhoe w/thumb, 7ft 6 way rear blade, chains front/rear, loaded rear tires, Kioti Canopy. For eveything else. |
#4 (permalink) |
I plumbed my father in law's compressor into the shop the other week, I used all in 1/2" PVC, so far so good, next step will be to enclose the compressor (vented to outside of course) so that it is quieter...
a schematic is attached... ![]() Enjoy Aaron Z |
#5 (permalink) |
An employer I worked for used PVC for airlines and all was well for quite a few years. Then one day the pressure relief failed and exploded the line like a bomb, there was plastic shrapnel inbedded in the ceiling and the walls. Only by the grace of God, no one was injured because they were in the cafeteria for lunch.
After seeing that, I would never use PVC for air lines. My 2 cents worth.
__________________
Curt "No man having put his hand to the plow and looking back is fit for the Kingdom of God" - Luke 9:62 |
#6 (permalink) | |
Quote:
__________________
Kevin BX1850, mower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, Corn Pro 18+5 Fifth Wheel
#7 (permalink) |
The one place we planned on putting one and forgot was on the outside corner, so as you were pulling a trailer out from the lot behind, you passed rigth by it. Now we use a 50' reel thats mounted inside and by the time you stretch across 25' of garage and 10' of apron you dont have much hose left.
#8 (permalink) |
This is scary, PVC and copper pipes used for compressed air??? I hope you guys have a good medical plan and plenty of insurance to cover a third party if they burst and injure someone!
I intend plumbing my shop from my static compressor, I will be using 3/8 seamless black pipe rated for compressed air. I don't want to be digging fragments of PVC or copper out of my body should they rupture under 120psi. |
#9 (permalink) |
Elite Member
Use PVC for compressed air AT YOUR OWN RISK! Copper or steel pipe is the preferred method for compressed gasses.
And, it is against OSHA regulations...not that you need to conform to those in your home-but you should be aware of the risk's involved in doing so... 19880520 The Use of Polyvinyl Chloride Pipe in Above Ground Installations This is from a major manufacturer of PVC: Why does Charlotte Pipe recommend against air testing piping systems?CP&F does not recommend air testing because a hydrostatic test is a better test. An air test is not conclusive. Changes in ambient air temperature will cause the air pressure inside the system to vary. If the outside temperature increases, the test pressure inside the system will increase. If the outside temperature decreases, the test pressure inside the system will decrease. This air temperature variance can mask a leak or fail a system that should pass. Leaks are easier to find with a hydrostatic test. Most importantly, air testing can cause injury or death. Cast Iron, PVC, ABS, and CPVC pipe and fittings for plumbing and industrial systems Search for "air" at the above link..
__________________
JD 4110HST FEL, 60" MMM, 60" Rear Blade, Ballast Box, Imatch, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, and much more "stuff" |
#10 (permalink) |
Just another point of safety, PVC deteriorates over time, it gets hard. If sunlight shines on it, it hastens the hardening process. Steer well clear of PVC for compressed air!!
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
