Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    Feb 2008
    Posts
    35
    Default Help- adjust JD 790 3 point hitch
    Help !!!
    I just had to replace the 3 point hitch adjustment fork screw on the right side of my beloved JD 790 (bent by the previous owner). I installed a new one and it seems to be too long because the right side of the 3 point hitch is lower than the left side (see picture). I can't raise the right side by the adjustment screw because it is all the way up as far as it will go, into the black adjustable lift link.
    Any ideas before I go back to the dealer?
    I tried to attach a picture (which is worth 1000 words) but it it doesn't work, will try again.
    Fast as ever-
    Eddie
    Attached Thumbnails Attached Thumbnails Help- adjust JD 790 3 point hitch-pto-jpg
  2. #2
    Super Member RobS's Avatar
    Join Date
    Jun 2000
    Posts
    7,133
    SW Michigan
    John Deere 790
    Default Re: Help- adjust JD 790 3 point hitch
    My first guess is it's too long but you might take it off and "center" the adjustment barrel so the same amount of thread are showing both top and bottom. That might allow for more adjustment.
    Good luck, aren't these 790s great machines!
    Rob
    John Deere 790, 70 FEL, 7 BH, 513 cutter and other fun stuff
  3. #3
    Platinum Member tomd999's Avatar
    Join Date
    Jul 2007
    Posts
    666
    Viva Manchvegas!
    '10 3320 cab
    Hiya,
    Always check your serial # against the latest parts list on line. A lot of times Deere makes minor changes and denotes these with serial # ranges.
    Here's what I saw on the 790 links:
    Up to SN 470331 lower yoke is part # AM876860
    SN 470332 and later lower yoke part# LVA800172
    Hope that helps,
    Tom
    Big and little Green tractors, Orange tractors and one awesome brown dog.
    "Congelo nos opus, quantum punitor ingravesco"
    "Behold, like the wild azz in the desert, go I forth to my work"
  4. #4
    Member
    Join Date
    Feb 2008
    Posts
    35
    Quote Originally Posted by tomd999
    Hiya,
    Hope that helps,
    Tom
    Tom,
    Great point. I did provide the dealer my S/N, but I'm not sure that they used it. I'll check with them tomorrow.
    Eddie
  5. #5
    Member
    Join Date
    Dec 2004
    Posts
    44
    Aiken County South Carolina
    John Deere 790
    I'm with Rob. Looks like you need to disassemble and get the center adjusted properly. As far as the correct part, you have the old one. Might want to check it against the new piece. I have a 790 also and I'm with you guys on a great machine.
  6. #6
    Member
    Join Date
    Feb 2008
    Posts
    35
    Just came from the JD dealer and after a mechanic looked at it, he decided that the turnbuckle (black part in my picture) is also slightly bent. So I had to order another one ($ 99). I only recently bought the 790 and this was bent when I got it.
    Thanks all - really appreciate your comments. This Forum is really great.
    E.
  7. #7
    Gold Member
    Join Date
    Feb 2008
    Posts
    262
    It looks like there is alot of adjustment left with that much thread showing.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
