HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Parts/Repairs
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 06-13-2008, 03:06 PM   #21 (permalink)
Default Re: Broke a bolt that has loctite on it - now what
Quote:
Originally Posted by KansasJim
Sorry - could I get a translation on that? I just plain old don't know what that is.
"bottomed in the threads" would be tightened into a blind hole with the end of the bolt forced against the bottom.
larry
SPYDERLK is offline   Reply With Quote
Old 06-13-2008, 04:15 PM   #22 (permalink)
AlanB's Avatar
Quote:
Originally Posted by woodlandfarms
I snapped the head off a grade 8 bolt (I think it is grade 8, will check tomorrow) that I put loctite on. I know how to easy out it, but how do I deal with red loctite? I remember someone saying hit it with a torch, is this correct?
Thanks for all the advice in advance...
If you put it on, hopefully you still have the bottle, and you know what Loctite you have. Go to the loctite site and they can provide you some info.
I am betting it is something like this, and yes, as it says up top, handtools and heat.
Loctite® 277™ Threadlocker - Product - Henkel
I am a real fan of the weld it out method, and yes, it will break most loctite bonds as well. As has been described here, do a drip, drip drip of weld, then drop a nut over the drip, then weld the drip and the nut together and remove. I usually use MIG process with .023 (small) wire.
Here is a thread that talked about it quite a bit, my picture does not have the nuts on the top, but on the little things in the picture it was not needed.
http://www.tractorbynet.com/forums/p...ght=weld+screw
Good luck.
AlanB is offline   Reply With Quote
Old 06-13-2008, 11:28 PM   #23 (permalink)
Gold Member
Flatheadyoungin's Avatar
i only read the first page....
some good advice....
without seeing what you are dealing with, i'd say use a washer, weld it on the broken bolt, then weld a nut on that......the heat will help break the loctite loose....
or, try a left handed drill bit....i know grade 8 is hard but if you guy a good one, it may still work......
the candle wax does work good but i'd say the loctite will keep the wax from wicking into the threads.......plus the oil will make it a little harder to weld...
__________________
TC45 Shuttle, 270 hours, 758C backhoe, 16LA loader
Well, I looks like I just bought myself a lot of work.....
Flatheadyoungin is offline   Reply With Quote
Old 06-14-2008, 10:55 PM   #24 (permalink)
New Member
Quote:
larry
Got it. Thanks.
KansasJim is offline   Reply With Quote
Old 06-16-2008, 06:36 AM   #25 (permalink)
woodlandfarms's Avatar
So, at the moment it looks like I lucked out in 2 ways. First, the broken bolt is not a grade 8. It is just a 2. Also, it is not one of the bolts that I put loctite on. I will look at my bottle of red in the morning, I did not know there was different grades. It was a twist tube and the red was pasty.
The bolts are on one of my 3 stump jumpers. These are older photo, just before I put on my hockey puck bumpers to prevent the blades from jamming under the jumper (a problem on this particular machine).
The hockey pucks have lasted, and probably under normal use you would get a year or more out of them. In my case.... 5 days but I consider that a success given my terrain.
broke-bolt-has-loctite-now-img_4466.jpg  broke-bolt-has-loctite-now-pict0945.jpg
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is offline   Reply With Quote
Old 06-16-2008, 09:07 AM   #26 (permalink)
ampsucker's Avatar
probably the grade of the bolt is the reason you're having this problem now. a grade 8 might have given you better service in this application.
amp
__________________
PM me with your email address to receive my Monthly Lawn & Garden Calender of Reminders. Helpful tips in your email each month.
Kubota BX24 (loader, hoe, 60" belly); Ford 800 gas tractor; Scott's/Deere 42" gas mower; 5' rear blade; 6' rear blade; 20' 7,000 lb carhauler; 5' dethatcher; 10" sleeve hitch, single bottom moldboard plow; middle buster plow; 600 lb roller; 3pt auger; front tire chains; Stihl hedge trimmer, weed wacker, chainsaw, blower.
Growing with you season by season.
ampsucker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
