JD 850 needs a clutch
   / JD 850 needs a clutch #1
PHIL850
MASS and Northeast kingdom of VT
JD 850
My JD 850 needs a clutch replacement. I have replaced Clutchs on small trucks before, but I am unsure about splitting a tractor in half to do the same. Bottom line, my PTO will not disengage, however the main drive clutch is fine. The tractor was originaly used as a loader mostly, and I suspect ware on the drive clutch has made the PTO clutch inoperatable. If you take up on the clutch rod adjustment you can get the PTO clutch to disengage, however at that point in the adjustment, the main drive clutch will fail to engage! So here I sit with out being able to brushhog my field. JD dealer mentioned a cost in excess of $2k to replace the same. Has anyone done such a job and can it be done without the use of the various special tools mentioned in the technical manual.
regards, Phil C.
   / JD 850 needs a clutch #2
Not sure Phil, but I'll be watching your thread closely as I forsee a clutch job in the next year or two.
   / JD 850 needs a clutch #3
I have the manual. My 950 is covered with the same one. It is just a standard seperation, no special tools. You will have to seperate the tractor at the bell housing blocking the transmission and walk the front half of the tractor on a floor jack. I would highly recomend you get the manual to see what you need to do, also contains specs you could only guess at. Cost in the $125 range. Did mine in 6-8 hours, but I have a gantry crane to use with the floor jack for the seperation. Use the drive line with the splines to align the clutch to the flywheel when tightening the pressure plate. Not that hard of a job, but special caution needs to be used to keep both halfs of the tractor level, aligned. If something moves on blocks and falls, could be a big safety problem. Buy the book, well worth the investment.
Chris
   / JD 850 needs a clutch #4
I had to split my 750 in half and I've built race engines for a good long while. Although somewhat mechanically inclined, this job just about made me nuts. Every thing that could go wrong did. I am no where in the same ball park as Chriswheeler nor was I set up like him not that it would make much difference. Just didn't have the temperment for it and admire very much the guys that do. Even though it may cost me 2 grand to do it next time, I will gladly pay the money and save my brain. And yes I had the manual and had to make special tools. If you have a short attention span and somewhat firery temperment with a short patience limit such as myself, it is not a job for the inexperienced in my mind. I'll make 2 grand extra somewhere and then give service the tractor. They'll have it done in 3 days where it took me off and on 3 weeks. If everything goes right, I guess its a simple job for an adept person. Oh yeah, I now have a noise coming from the PTO I never had before but will I tear it apart again?... not in this life time.
   / JD 850 needs a clutch #5
One thing I forgot to mention is plan on replaceing your throw out bearing, pilot bearing, and springs. All of these are cheap parts, you wouldn't want to have to split the tractor again to replace these. This isn't a hard job at all, you just need a flat place to work, some tools, the manual, and the right temperment. Most folks will do just fine. Buy the book first, look at the job, decide what to do. For $2000 you could do this job 4 times or pocket $1500.
Chris
I have the Technical Manual for the Tractor. It shows two special tools, one is the alignment tool for the clutch plates. I suppose I could use the Transmissions input spline to do the same, if it is no big deal to remove it from the tranny. The second tool is a gauge for setting the clutch fingers to a certain height I believe. I don't have the manual in front of me as it is north at my place in VT along witht the Tractor. Oh ya did I mention that I visit this place on mostly weekends, and this project would have to be done then.
My tractor is also 4 wheel drive, adding a little more work to the split. A crane or chainfall seems like a must in this case as I can't imagine balancing two halfs on a bunch of wooden blocks and floorjacks. What I realy should do is trade it in on a replacement, but money supplies prohibit such a deal at this time. Besides I have had two separate JD Dealerships tell me that these models (750, 850, 950, 1050) are great tractors (made by Yanmar). OK, so I am still on the fence on this one. Guess I will have to study the Manual a little more and think this one through.
Phil C, sometimes in mass, and some times in the North east kingdom of Vt.
   / JD 850 needs a clutch #7
I split a Ford 10 years ago and paid "a guy that fixes tractors on the side" to help me. I was the brawn and he was the brain. Cost me $100 for his time.
Keep the two pieces aligned.
Go for it.
Well I did some more research on this. I priced out a replacement clutch from John Deere on line. Part# AM878710 cost $1976.27 not including shipping and handeling!!! This is for the entire clutch minus things like throwout bearings and assorted stuff that should probably be replaced at the same time (OUCH). To replace just the Drive Disk P/N M802499 they qoute $275, and for the PTO Disk P/N M804454 another $295. Now I would hate to cheap out on this and only replace the Disk/s to later have additional clutch issues in the future. Lets face it, the labor to split this thing has got be a sizeable chunk as well. I guess this is what happens when purchasing used. I will think this through some more. ANyone know of a good Tractor Mechanic that hangs his/her shingel in Nrothern Vermont?
Ciao, Phil
   / JD 850 needs a clutch #9
Phil.
What you need to do on the parts is to find a clutch rebuilder. You can either send you clutches and pressure plate off to them for rebuild or exchange with them for a set that has already been rebuilt. I have split a lot of tractors in my life and I have never used anything but rebuilt units.
I have always used two floor jacks to do the split but you can use one floor jack and a cherry picker, an A-frame or over head gantry. Be sure to put a wood wedge on each side of the front axle so that the engine assembly won't fall over. The special tools that you will need are: a input shaft with both clutch shaft diameters and then a finger adjustment gauge.
Good luck.
I have found a rebuilt clutch for little less than half of a new one. (now things are getting a llittle more reasonable). But I still need to locate the special tools needed, the Clutch disk alignment tool and Finger height alignment tool. I could probably just turn down a piece of shaft on the lathe for the disk alignment tool and mimic the transmission input shafting, however I am unsure of the Finger alignment tool. This too could be made pretty easily, if I had the proper demensions. JD parts on line list these puppies out at $63.53 and $72.17 (not in stock either!). Not trying to Cheap out here, it's just that this project was not in this year's budget, So I need to keep it as low as possible before presenting this to the family Finance officer, if you catch my drift.
regards,Phil C.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
