HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Parts/Repairs
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-14-2008, 03:43 PM   #11 (permalink)
Elite Member
wushaw's Avatar
Default Re: Looking for suggestions for TS electrical problem
Quote:
Originally Posted by George2615
Like Vic said, use a test light. Disconnect the negative battery post and connect a 12V test light )or a voltmeter) between the post and the cable. With the tractor key off the light should not be lit. If it is then you have a circuit drawing current. Pull out tractor fuses one by one until the light goes out. That will be the circuit draining the battery. Just remember to put the fuses back in the right places later.
A volt meter is not good for this test since since you can get 12v but no current draw. It takes amperage to light up a light bulb.
A test light is the best method for checking for a draw when ya go to pullin fuses and wires.
__________________
Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB.
wushaw is offline   Reply With Quote
Old 06-14-2008, 04:57 PM   #12 (permalink)
yankeerider's Avatar
Coupla suggestions:
Make sure the top of the battery and connections are clean. Batteries can discharge themselves over a period of days through dirt on the top.
If that voltage measurement with the ground cable removed was terminal to terminal, you've likely got a bad cell in the battery. Should have 12 volts with no load. (I'm assuming the 14 volts you measured "under load" was actually with the engine running.)
If none of these answers make sense, borrow a multimeter with DC current measuring capability. Connect it in series with the battery when everything is off and see if there's any flow. Trying to diagnose light current drains using voltage measurements can be difficult.
__________________
Jerry
JD 755 w/70 loader, 60" MMM, DR 3pt chipper, Woods RB60 blade, 48" KKII tiller, 8 hp tow behind Giant Vac
Gator HPX 4x4 Gas
yankeerider is offline   Reply With Quote
Old 06-14-2008, 05:55 PM   #13 (permalink)
New Member
Yes, 14.x was with the engine running.
I used a test light this time and didn't get a light from the negative cable to the post with the key off. In light of that, here's my assumptions:
1) not a bad alternator because I was getting 14.x across the posts with the engine running and i'm not running the tractor long enough to drain the battery with a bad alternator.
2) not a short cause I'm not getting a light on the tester with the negative cable disconnected and testing in sequence between the neg cable and neg post.
Agggh.
Guess I'll check the voltage across the posts again, but think I did that already and it was at 12.x.
Posts are clean.
Think I should be focusing on the battery itself?
Thanks.
fishpredator07 is offline   Reply With Quote
Old 06-14-2008, 07:46 PM   #14 (permalink)
Willl's Avatar
A way to find out for sure would be to disconnect the fully charged battery, wait a few weeks, then reconnect and turn the key.
__________________
My PhotoBucket
If you can read this, your 'Ignore List' isn't working.
Willl is online now   Reply With Quote
Old 06-14-2008, 10:43 PM   #15 (permalink)
Elite Member
wushaw's Avatar
Get a hydrometer ( any parts store will have them ) and check each battery cell electroylite level.
Put battery on a trickle charger over night before checking.
Also you should have like 13.2 volts in a 12v battery.
__________________
Old 06-18-2008, 09:50 AM   #16 (permalink)
New Member
Checked the water. One cell was almost empty. The others were all over the map on the hydrometer readings. Topped them off and charged it up yesterday. 13.2V. This morning, 12.6V and with the hydrometer one cell was null and void. 2 were fair and 3 were good. Will be taking the battery back to the supplier this evening. Thanks for the advice, I've learned a bunch. Hopefully this does the trick.
Old 06-18-2008, 08:57 PM   #17 (permalink)
Elite Member
wushaw's Avatar
A hydrometer is a very good tool to have on hand to check the health of a battery.
__________________
Old 06-19-2008, 11:28 AM   #18 (permalink)
New Member
parts store confirmed the battery was bad and I'll get a free! replacement. I'll pick that up and install tonight.
Over the course of the next few weeks to a month I'll know if that was truly the root cause of my problems but seems like it. Meanwhile, I can start going after my hydraulic problem....Thanks all!
Old 06-19-2008, 05:16 PM   #19 (permalink)
Battery voltages ( 12V and 6 V) and electrolite specific gravity should be...;
__________________
Kubota B3030 with 40 amp alternator kit; LA403 FEL; 60 inch backblade; sub-soiler; ballast box; EzMover hitch; Payne clamp-on bucket forks; a HD set of smaller discs and a 60" landscape rake with dolly wheels
Hobart HH140 Mig welder
Hobart HH210 Mig welder
Sully2 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
