#11 (permalink) | |
Quote:
I second that, Brian Mo this is what you will see with your 1100. The pics are for 1700 or bigger brother to your 1100. JC, ![]() ![]() ![]() ![]()
__________________
Ford 1700, 60" Woods Rotary Cutter, home made 3-pt boom ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry All and 30" Dirt Scoop). |
#12 (permalink) | |
Banned
Quote:
#13 (permalink) | |
Gold Member
Quote:
__________________
Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer. |
#14 (permalink) |
Super Member
When I had issues with the engine in my dozer and then later on in my dump truck, I tried everything I could think of to avoid doing it right. I searched and looked for anything that could possibly create the problems, then spent the time fixing those things with the hope that it would solve my bigger problems. I don't know for sure how much time or money I wasted by doing this, but it was significant.
In the end, I had to do it right and deal with the expense and time that it took. It wasn't fun, it wasn't satisfying, it wasn't anything good. But it's done and I'm glad to be over those issues. When I want to use either piece of equipment, I can without worry that it will break down, not start or not have enough power to do the job. I'm not sure what an 1100 is, other then a Ford tractor of some kind. I'm guessing that it's got a few years on it and probably never had any major repairs or issues before? Being old, the head probably has considerable wear to it. The valves and valve guides should be replaced. The head should be resurfaced and the injectors replaced. It will add up to allot more money, but you will have a stronger, more reliable tractor for it too. If the head is off anyway, then it's sure a shame not to do all you can at the same time. At the very least, have it boiled or dipped, to clean off all the build up that will be on it. Good luck, Eddie
__________________
My Goals for 2008 1. Fishing and Hunting with my kids. 2. Build my storage Shed. 3. Put my outside access bathroom together. 4. Fence in a quarter acre for Turkeys. 5. Build my gazebo for my front pasture. 6. Finish back pasture and plant it in Bermuda. 7. Start my food plots. 8. Build a comfortable deer stand for two. 9. Build a wood burning fireplace in my home. 10. New flooring in my home. 11. Build a pasture sprayer. 12. Get my old jeep running. |
#15 (permalink) | |
Super Star Member
Quote:
A plugged radiator is it's own problem.. one with only pinholes is gonna cause you to replace that headgasket again after about 10 minutes of runtime. A proper flowing radiator shouldn't be adversly effected by a decent sealer. Many tractor manufacturers OEM a brand they reccomend for their engines. Also.. many engine rebuilders use engine cubes in newly rebult engines as a prophylactic... soundguy |
#17 (permalink) |
brianMO,
I did one (head gasket) on my 1310 and it was not a bad job at all. Be sure to have a manual on hand so you can follow the proper torque sequence when re-installing. I'd say it's better than hoping an additive will stop the leak. I also lapped the valves and replaced the valve seals at the same time. Of course with mine I discovered someone had repaired a hole in the block with JB Weld or something similar right after I got everything back together. The hole was behind the starter motor and I found it when it started to leak coolant. I redid the repair (with JB Weld) and it still was seeping so at that point I used some radiator stop leak. Has been holding and working well for two years. Unfortunately now the clutch has failed. The good news is the price of scrap is the highest it has ever been. ![]()
__________________
MIKE "I have friends in overalls whose friendship I would not swap for the favor of the kings of the world." "Iowa Child" by Sarah Hall Maney |
#19 (permalink) |
As a previous owner of a Ford 1100 4x4, I would really like to mention that those tractors were built exceptionally well as mine held up to continous abuse, low maintance and outside storage most of it's life. The only things that EVER broke on it were things that were a direct result of something I or other owners did.
I also realize the high cost of maintaining one of them. There was a post a while back about someone pricing a muffler for one, and it being just short of the value of gold. ($500 range) I purchased a very similar one used and made an adapter block to make it fit for the now current owner of that fine tractor. So if you decide that you aren't going to fix the tractor, I am sure that we can get you better than scrap value for it, and you won't have to strip the tires/fuel/oil/antifreeze out of it prior to it being picked up. My old one has need for a couple of parts that "might" make the trip worthwhile should you decide to take the easy road and find a replacement tractor instead. I also agree that the sealer idea, even if it works, probably won't be a good long time fix. You might get lucky and get a season out of it, but in the long run, your going to have to bite the bullet and spend some money. David from jax
__________________
A serious accident is one that money won't fix. |
#20 (permalink) | |
Quote:
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
