Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Not really a hydro trans.. but more akin to a 'power-shift' gear trans...
soundguy
soundguy
John already beat me to the punch on the balancer. Yes, the Select-O-Speed (SOS) transmission was an early hydro transmission that used a combination of hydraulics, tension bands, valves, and clutch packs to deliver 10 forward and 2 reverse speeds (+ PTO). I think these trannys came out in around '59 actually, but were greatly improved in late 60's and continued to be used with the ford 2000-6000 series. More knowledgeable TBN's can give you a more complete run-down of history and mechanics for the SOS .
In my case, the SOS actually was working reasonably well (when the engine seized), but the PTO no longer engaged properly. Unfortunately, unless I have a broken PTO shaft or cable, the repair will probably require me to dive into the transmission. Looks like the PTO and inching pedal (feathering valve) run off of the band 2 (Wow- that clears it up doesn't it? )
Engine first - I say!
Pete
