Results 1 to 10 of 29
09-20-2008, 06:57 PM #1New Member
- Join Date
- Sep 2008
- Posts
- 14
- Location
- newglasgow /antigonish/nova scotia
- Tractor
- ac hd6 crawler
track comes off 1960 AC hd6 dozer
the track came off, after some considerable effort I got it back on .
now its starting to come of again on the idler wheel and I notice the side that the track is on is 3 or 4 inches farther out from the body of the machine than it should be ,what is going on that the hole side of the machine can move over ,and its not just the track because the blade is binding and I can look down at the leaf spring and its 3 to 4 inches out of alinment and the track is coming off in the direction of the body that would put it closer to the body .
there most be something going on with the rear end I think ,does anybody have any idea what is going on.
09-20-2008, 07:16 PM #2
Re: track comes off 1960 AC hd6 dozer
Something has happened to the oscilation bearings at the rear of the trackframe . Bearing cap missing or broken arm maybe , look under the back of the machine .
09-21-2008, 12:13 AM #3
I just got your email but mine is playing up so i'll answer your question here . If you look under the back of the machine you will see that the trackframes have solid arms coming off at their mid section which run to the back of the machine and are attached to an axle shaft with trunion bearings that have caps to attach them . The only two places the trackframes are attached are at the sprockets on the outside and by the arms underneath . The front end floats on the leaf spring . This allows the tracks to oscilate on uneven terrain . It can only be at these points that could allow the trackframes to become out of line . Once you stick your head under the machine you will see what i mean .
09-21-2008, 09:51 AM #4New Member
- Join Date
- Sep 2008
- Posts
- 14
- Location
- Tractor
- ac hd6 crawler
thanks ,sounds like you know what your talking about.
09-21-2008, 06:10 PM #5New Member
- Join Date
- Sep 2008
- Posts
- 14
- Location
- Tractor
- ac hd6 crawler
I looked under the machine ,the arm is not broken and the caps are there and tight, the cap at the sprocket has a 1/16inch gap showing on one side of the cap ,when I tried to tighten it down the bolt stripped .I would think the bushing on the end of the arm would be more likely to be the problem ,do you think so.
or do you think the 1/16th inch gap would be the problem. also this track frame is different than the one on the other side,it has been replaced at some time in the past with a track frame from something else ..and the 2nd previous owner had put a pipe running from one track frame to the other ,now aparently to correct this problem but the 1st owner before me removed it .how do you think I should procede now.
09-23-2008, 02:42 AM #6
I'm sorry , it sounds as if it has been cobbled together . It hard to say now , that 1/16" of an inch back at the sprocket would be 3" at the front , but yes i think it also has internal wear . I can hardly imagine what they have done to get a different frame to fit .
09-23-2008, 04:47 PM #7
Yeah bearing, bushing somewhere. Had a JD350 crawler that started throwing the track...just before the final drive went out. Not fun. Heavy stuff.
L2500
09-25-2008, 07:08 PM #8New Member
- Join Date
- Sep 2008
- Posts
- 14
- Location
- Tractor
- ac hd6 crawler
it was the bearings as the picture will show you.
10-01-2008, 07:05 PM #9New Member
- Join Date
- Sep 2008
- Posts
- 14
- Location
- Tractor
- ac hd6 crawler
starting the repair,track laid out ready to take the cap off and jack the dozer off of the track frame.
10-01-2008, 10:49 PM #10Elite Member
- Join Date
- Aug 2004
- Posts
- 2,706
- Location
- North of Mtl,Que,Can (Ste Adele)
- Tractor
- MT180D
Had a HD6 a few years back.
Powerfull for it's size and did lots of work for me.
My only bad luck was snagging a hydraulic line to the blade lift cylinder and taking a hydraulic oil bath/shower.
Paid $4000, earned me $8000 and sold it for $4000. Was not a bad deal all in all.
(also did all my jobs for mere fuel costs)
