6sunset6
- Joined
- May 6, 2007
- Messages
- 1,056
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
Ahh Knew I should not have done that. No before pictures but midway pictures and question. Welded a thumb base to the top of my bucket. Worked well for brush and logs . Big rock wrong. bucket is 10g .134 in thick. I decided to cut out the top and weld in a rectangular tube section. 3 x 5 x 3/16 68" long was $80. Jig saw, or friends plasma or my OA. Used OA but maybe jig saw would have worked. I don't like to use OA unless I really have to. Anyway cut was a little ragged but it's all buried under the weld. I am not the worlds greatest welder but then I have never had anything come apart either. So here is the question. Do I need to reinforce the 3 x 5 thumb mount ? Trade off to FEL lift. I was thinking the tube is really stiff and maybe a vertical web inside the bucket maybe 1/2 way down. Web would be in tension . How about under the hooks.? The one on left will be turned around off course.
