Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,870
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe Deere Z930M ZTR
    Default Best way to remove this bearing race?
    I had the bearings in my steering column and steering box go out recently. The new bearings came with new races which is a good thing because the old ones are pitted. The old race in the end of the steering column appears to be pressed in (rather than a permanent part of the column and since the new bearing come with races I assume they are replaceable but the manual isn't clear on this point) and I am now faced with how to get the old one out (if indeed it is meant to come out)
    I have a crow bar that fits perfectly inside the column and against the bottom edge of the race. At first I tried fast repeated "gentle" taps against the race, trying to knock it out and slowly progressed to full out beating with a 3# hammer but so far it hasn't budged. I really don't want to just destroy it while attempting to remove it but I am beginning to wonder if somehow cutting the old one out isn't going to be my only option. I have thought about trying to make a puller but the inside edge is very thin (0.075") so there's not much to grab ahold of. I have it sitting in penetrating oil right now in hopes that will help later. I have considered heating it but haven't gone down that road yet. Anyone got any suggestions befor I go any further???
    Attached Thumbnails Attached Thumbnails Best way to remove this bearing race?-009-jpg   Best way to remove this bearing race?-008-jpg
    Darryl
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,561
    Texas
    Default Re: Best way to remove this bearing race?
    I can't say whether it would work on that or not, but one way I've removed and installed bearings and races that were too tight was to heat the outer piece (just boiling water worked for me), then dry ice on the inner piece (the race you want to remove), then a sharp rap with that 3# hammer.
    Bird
  3. #3
    Join Date
    Feb 2005
    Posts
    626
    Southern Indiana
    BX23
    Run a bead of electric weld around the inside of the race. That will cause it to shrink when cooled, and should drop out.
    ron
    I was better, but I got over it.
    Life may change us, but we start and end with family.
  4. #4
    Join Date
    Mar 2000
    Posts
    40,561
    Texas
    Ron, that's something I never tried or thought of (maybe because I didn't have a welding rig at the time), but that certainly makes sense and sounds like a good idea.
    Bird
  5. #5
    Gold Member
    Join Date
    Sep 2008
    Posts
    280
    NE Missouri
    Case DX35
    If there's an auto parts store near you that loans tools,such as O'Reillys or Auto Zone,you might try a pilot bearing puller.
  6. #6
    Elite Member
    Join Date
    Oct 2006
    Posts
    4,709
    Ohio
    GC2310,
    If you have access, I have seen freon used to cool the race, after the whole part is heated. it will come right out. Reverse to install.
  7. #7
    Join Date
    Sep 2008
    Posts
    237
    Fairbanks Alaska
    Kubota B8200, 1953 International "Super C"
    I was in NAPA last week and had to wait in line for 30 minutes again, and saw they had a can on the shelf witch was something like liquid nitrogen. just for this use. What i liked about it was that it was only 5 or 6 bucks and I didn't have to heat any thing.
  8. #8
    Gold Member
    Join Date
    Nov 2006
    Posts
    396
    Barossa Valley, South Australia
    Duetz DX3.70, Fendt 305LSA,260S & 205P,Kubota B6100E & 3 x B5100E & RTV900, Caterpillar 428C
    Quote Originally Posted by 638 View Post
    Could be a little tricky but it's certainly something I'd never thought of and could just work!
  9. #9
    Platinum Member bjcsc's Avatar
    Join Date
    Feb 2007
    Posts
    559
    Johns Island, SC
    JD 5225, JD 555B, JD 333E, JD 225DLC
    The welding idea is interesting! If you can't pull it and temperature manipulation fails, you might have to break it out. Races are hard and a couple good hits with a cold chisel should break it...
  10. #10
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,807
    MA
    L5450, L48, L3250, L345
    Quote Originally Posted by Kernopelli View Post
    ,,,,,,,. The old race in the end of the steering column appears to be pressed in (rather than a permanent part of the column and since the new bearing come with races I assume they are replaceable but the manual isn't clear on this point) and I am now faced with how to get the old one out (if indeed it is meant to come out)............
    Another method that usually works is to cut it out using a Dremel tool & abrasive disk to make a slot in the bearing race. I've taken side bearing races out of a transaxle this way - even with the unit still in the car. Sometimes the only access is to cut a long diagonal slot - but it works well.
    L345, L3250, L48, L5450, never enough attachments
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
