been helping a friend to bring his 8N back to live after years of just sitting in the yard(The tractor , not me)Got it converted to 12volts,electronic ignition and installed a new radiator,greased the thing and changed the motor oil(sludge).Tractor fired right up,hydraulics and pto work fine.One problem is the clutch.Can not put the tractor in any gear while running,gears grind.adjusted the clutch but makes no difference.I can put the tractor into reverse and than start it.Could the clutch be "stuck" from years of sitting up?if so is it a common problem and how to cure it?
thanks in advance,Ben
