I need some help with my 3 point hitch valve. Last year it was stiff. So stiff in fact that it would flex the arm of the valve where the lever is rather than move the valve. I dug into the valve to see if I could free it up. Well after taking it apart to free it up I guess I did to good of a job. Now I have the oposite problem. It is so free that it won't stay up on its own. I have to hold it or put a bungy cord on it. Also if it is all the way up it puts a load on the tractor's hydraulic system that you can feel and hear and it takes power from the tractor. Then in some spots between up and down it will cause the hydraulics to jump or surge so you have to mess with it to find a sweet spot then hold it there while you are working. I have been living with it but it is becoming a pain it the rear. The hitch goes up and down fine so my wonder is, is there a way to tighten up the valve and get rid of the surging or do I need a new valve.
Thanks
Thanks
