Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Apr 2009
    Posts
    6
    Default continental L head 4 cylinder engine
    Hi guys..... I have a 4 cylinder continental L head which runs great, but
    really burns oil. What all would this engine need for a rebuild?
  2. #2
    Platinum Member spruce Deere's Avatar
    Join Date
    Feb 2009
    Posts
    758
    Northmost Idaho
    John Deere 790 w/ 300 loader
    Default Re: continental L head 4 cylinder engine
    How big?? I have an original 1948 hand crank, y-112 four cyl. power unit. I have not started it in a while but it ran excellent and used little to no oil. I totally give it a face lift. I did not do anything to the motor itself due to its soundness. PM me for more
    Attached Thumbnails Attached Thumbnails continental L head 4 cylinder engine-old-computer-pictures-1553-jpg   continental L head 4 cylinder engine-old-computer-pictures-1551-jpg   continental L head 4 cylinder engine-old-computer-pictures-1555-jpg   continental L head 4 cylinder engine-old-computer-pictures-1554-jpg
    790 JD W/ 300 loader
    Lots of implements for loader and 3pt
    Can't do it burn'n diesel, is not worth do'n
  3. #3
    New Member
    Join Date
    Apr 2009
    Posts
    6
    Its an F400, but I don't know the hp rating.
  4. #4
    Join Date
    Feb 2009
    Posts
    758
    Northmost Idaho
    My reproduction manual for L-head continentals show a F400 power unit picture but no specs. It does show specs for 4 cyl f series f124, f135, f140, f162, f163. And F series specs in 6 cyl. f186, f209, f226, f227, f244, f245. Look at montesequipment.com they specialize in older continental motors. You are lookn to rebuild, you will also need a manual. I got mine at jensales.com and there also manuals available at wisconsinmotors.com Hope some of this helps.
  5. #5
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    I have a continental F162 in my Terratrac bulldozer. I had no problem getting parts to rebuild. I got most of them from NAPA auto parts. It was probably 15 years ago that I did the rebuild. I guess parts availability could have changed by now but I would give then a try. I was able to get all new rings, bearings,valves and gaskets.
  6. #6
    Veteran Member CCWKen's Avatar
    Join Date
    Mar 2005
    Posts
    1,197
    South Texas, USA
    Ford-3910, JD-420C, Kenbota-Custom, IH-2606
    F400 is the series. There should be a tag on the left side of the block above the dipstick to indicate which F model you have. Many parts are still available but not many are interchangeable between the models so you need the number off the tag.
  7. #7
    New Member
    Join Date
    Apr 2009
    Posts
    6
    No there is no numbers tag above the dipstick....the only numbers
    are the casting numbers of F400 A 421/S CWC. I gave these
    numbers to Foley marine & industrial engines and they said they
    have all the parts for this engine, so I assume that was a good number
    for them.
  8. #8
    New Member
    Join Date
    Apr 2012
    Posts
    1
    Jeanerette, LA.
    1220 ford
    There are alot of factors that come into play. The block will determine alot of them. tear down and visual inspection is a must.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
