Results 21 to 30 of 36
06-19-2009, 11:58 PM #21Bronze Member
- Join Date
- Nov 2007
- Posts
- 84
- Location
- New Brunswick, Canada
- Tractor
- JD 755, Kioti DK40SE
06-20-2009, 12:07 AM #22Veteran Member
- Join Date
- May 2009
- Posts
- 1,616
Re: Voltage reducer for Glow plug?
I see, one terminal is a stud and the other is a collar. Now we need to know the current and voltage drop for one plug, that will lead us to the wire gauge and dropping resister.
06-20-2009, 12:10 AM #23New Member
- Join Date
- Jun 2009
- Posts
- 15
- Location
- Val-d'Or, QC
- Tractor
- International B414
06-20-2009, 12:24 AM #24
06-20-2009, 12:26 AM #25
06-20-2009, 12:58 PM #26Gold Member
- Join Date
- Apr 2008
- Posts
- 439
- Location
- Central Texas
- Tractor
- Current, Power King (antique), Soon to have JD 5103
OK let's keep it simple. To find current us a multimeter set to ohm's and read the resistance. The plug says it's a 0.9V. So ohm's law says I(current)= V(voltage)/R(resistance). Current though a series circuit is constant. To find the resistor needed would be 12V - 3.6V(4 plugs) = 8.4V and plug it into ohm's law again this time finding resistance for the resistor (R=E/I). The last thing is to find the power in watts that the resistor will need to handle. This is just another variation of ohm's law (P=E*I). To solve this would be P=8.4V*I(current found earlier). Size the resistor the next size larger to be safe. Now to keep it simple for the indicator. 12V to switch, switch to 12V light and resistor, light to ground and resistor to plugs.
Hope that helps.2008 5103, FEL, 6ft. HD Box Blade, 6ft. Rotory cutter. And many more to come.
06-20-2009, 01:23 PM #27Veteran Member
- Join Date
- May 2009
- Posts
- 1,616
Sorry to bust your bobble Rwolf, you have the correct idea; however, you missed some important points.
You are measuring the resistance of a COLD plug and trying to use that value to calculate the current when the plug is HOT. The resistance of a hot plug would be many times greater then when cold. Try the same calculations with a light bulb. A 100-watt bulb at 120 volts will have a resistance of 144 Ohms when on.
06-21-2009, 09:55 PM #28Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,106
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I agree.. for an incandescent element.. hot resistance will be drastically different than cold resistance.
soundguy
06-22-2009, 03:06 PM #29Gold Member
- Join Date
- Apr 2008
- Posts
- 439
- Location
- Central Texas
- Tractor
You are correct and no bubble bursted. I didn't take the heat issue into account because I didn't have the specs for the glow plugs and also had forgotten about that aspect. But it will get you in the ball park and you could always up the resistance value to the next larger value to reduce the current. Either way the OP wouldn't be blowing plugs immediately.
06-22-2009, 04:42 PM #30Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,106
- Location
- Central florida
- Tractor
I think an inline lamp is where I would start looking .. they make good current limiters that stabilize pretty quickly.
soundguy
