Quote:
Originally Posted by woodlandfarms My grandfather worked at the Deer factory in Dubuque, IA for his entire life. I did not know him well, but he was a tinkerer. When he tore down odd stuff to repair, he always had a notepad and a pencil. He made elaborate drawings of his teardowns, so he could get them back together again.
So, how do you keep track of all of this? You have a shop manual? Use these photos? or are you just one of those with a photographic memory? |
I was hoping to get a tour of the JD tractor factory in Waterloo, IA when I
was nearby a few years ago. Went to the combine factory in E. Moline, Il
instead. Very enjoyable, highly recommended.
When I take things apart, I don't make drawings, and the photos I take are
not to help me with reassembly. Mostly I go by memory, but I try to figure
out how an assembly is supposed to work, which means I don't have to
DEPEND on memory when it goes back together. All fine in theory, but
I also lay out complicated things (engines, trannies) is a very organized
manner. I tried to illustrate that in a previous posting showing my engine
parts. I did not want to depend too much on memory there, as it was
more than a month between disassembly and reassembly. Also, some
things need to go back just so: pistons are oriented one way, valves
must go back in the same guide, etc.
As to shop manuals....I always get them for any tractor, car, or truck I
own. They are necessary in some cases (specs, special procedures,
adjustments, etc.), but they are woefully incomplete in many areas. The
parts diagrams are almost more important. These are fortunately free for
Kubotas and Deeres, as PDF files, or pix captured off the JD Parts site.
I buy the JD parts PDFs off eBay, however, since they are more usefull
than the pix on JDParts.
I dread a project that has been completely disassembled by someone else
first, since analysis is so important to me. As a side note, I bought a BMW
M3 coupe 6 years ago, mostly for the wife to commute with. That is
despite my research that said how unreliable BMWs were. Little did I know
that BMW DID NOT PUBLISH A SERVICE MANUAL! DIY owners buy a
manual from a 3rd party and make do with that. The Bentley BMW manual
is not as bad as other 3rd party manuals (I&T, Haynes, Clymer, Chilton, etc),
but it was woefully inadequate. Fortunately, there are many, many self-
published how-tos on the WWW that show hardcore DIYers how to fix the
many common BMW problems. I have never posted on a BMW forum, but
I have used them SO many times.
AMPA: I have bought tons of HarborFright stuff, and here is a clear winner:
Item#93230, 24" tire iron, $5.99. This product works very well, and it is
so cheap that I bought a pile of them to use the tough steel in welding
projects, as well as for their intended use.
