HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Parts/Repairs
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-07-2009, 09:44 AM   #291 (permalink)
Default Re: John Deere 4300 complete rebuild
My 4400 has no springs in the fuel cap door. It will flip up when I transport it on the tractor sometimes, or if I go over 40 MPH backwards.... Just one pin. Let me know if you need a pic to clarify.
Wayne
Wayne_H is offline   Reply With Quote
Old 11-07-2009, 02:42 PM   #292 (permalink)
dfkrug's Avatar
Quote:
Originally Posted by kennyd View Post
BTW-I have no "clips" but 2 springs.
Nice pix, Kenny. Thx for posting. I see how the springs go in now. My
hood looks like it will only accommodate one spring that way as the molding
is different. On one of your photos, I highlighted the two parts that hold
one side of your springs. I only have one of those hoops in the plastic!
I sure do not see how the clips go in. Matt: does yours have clips? Wayne:
I see how nothing holds the door on if you do not do something to secure
it. It seems one little bump and your door flies off.
This is what happens when you have to depend on the parts diagrams to
buy and assemble parts that you never had before. Note: the remaining
rental 4300s often do not have such "optional" parts as the fuel door.
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 11-07-2009, 02:59 PM   #293 (permalink)
Johndeere3720's Avatar
So, is the hood mounted on the tractor yet? Do you have any pictures of the thing together? This thread inspired me to fix a tractor myself so today im getting a Simplicity 9518 to fix up. I cant wait.
__________________
JohnDeere L118 2wd with R3s
Yanmar 169D 4wd with loaded R1s
Simplicity 9518 2wd with R3s (Rebuild)
Craftsman trailer, Modified KingKutterXB boxblade, Mitchel Field mower, Montana grader blade, JohnDeere imatch, Old rusty arena rake, and Modified & Restored Black palletforks
Can you believe im only 14!
Nothing runs like a Yanmar
Johndeere3720 is offline   Reply With Quote
Old 11-07-2009, 03:07 PM   #294 (permalink)
dfkrug's Avatar
Here I have rebuilt my joystick control for the FEL valves (SCV). I
suspect that many tractor makers are moving to the fully enclosed and
sometimes cable-operated mechanisms here. It is vey hard to get
proper lubrication in there, so after 500-1000 hrs, your joystick gets
really sloppy. Here is the good news: the replacement parts are
actually reasonably priced. The two tie rods are $13 ea and have rubber
booted ball joints. I also replaced my main stepped pivot shaft, guide,
and lock nut. The 2nd (blurry) photo shows these critical new parts.
I am amazed at how tightly the joystick works now. $50 well-spent here,
IMO. I will mount this to the gearbox when I get my load of hyd fittings
that I have ordered.
john-deere-4300-complete-rebuild-scv_rebuilt.jpg  john-deere-4300-complete-rebuild-scv_rebuilt_3.jpg
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 11-07-2009, 04:15 PM   #295 (permalink)
dfkrug's Avatar
Here is pretty much where I am as of yesterday. I am still screwing
around with the wiring harness. It has to go into some pretty tight
places. The instrument panel has been renewed with new glass and I
have been successful making the black guage backgorund look MUCH
better. The manual said use alcohol, but that left it looking very
cloudy and dull. I experimented with Armor-all and it worked great.
I sure hope the instruments work....a new panel costs too much.
I have also straightened the bent foot step and FEL hardline support
bracket. They must have taken an impact or two...
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 11-07-2009, 04:20 PM   #296 (permalink)
dfkrug's Avatar
Here is the footstep 'before' picture. I used the press to tweak it
back into shape.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 11-07-2009, 04:51 PM   #297 (permalink)
Wow, its looking good. Very nice job.
__________________
Old 11-08-2009, 02:15 AM   #298 (permalink)
mjncad's Avatar
Quote:
Mine doesn't have springs, and there is a black plastic clip of some kind covering the gap where you've added the yellow lines to your picture. My fuel door is front hinged and flaps like a rain cap on an exhaust stack.
KennyD: What is that black plastic gizmo in the middle of your fuel door for?
__________________
Measure it with a micrometer, mark it with chalk, cut it with a torch, beat to fit, paint to match, inspect it with a microscope.
Google finally fixed Picasa web albums problems I was having. Latest postings.
http://picasaweb.google.com/mjncad/HydraulicsUpgrades#
http://picasaweb.google.com/mjncad/ToolsPower#
mjncad is offline   Reply With Quote
Old 11-08-2009, 08:21 AM   #299 (permalink)
Super Member
kennyd's Avatar
Quote:
GDO (garage door opener) Remote.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 11-08-2009, 11:14 AM   #300 (permalink)
[quote=dfkrug;1798952]I sure do not see how the clips go in. Matt: does yours have clips? Wayne:
I've got two clips that go in from the bottom which hold everything in place. I hope thse pics clarify that.
Wayne
john-deere-4300-complete-rebuild-fuel-cap-1.jpg  john-deere-4300-complete-rebuild-fuel-cap-2.jpg  john-deere-4300-complete-rebuild-fuel-cap-3.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.22368 seconds with 9 queries
