HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Parts/Repairs
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-29-2009, 01:36 PM   #31 (permalink)
dfkrug's Avatar
Default Re: John Deere 4300 complete rebuild
Quote:
Originally Posted by mjncad View Post
My 4200 is a 2001 and has about 485 hours on it. As I recall the owner's manual says to get a valve adjustment every 500-hours. Mine runs just fine, and although I'm not fanatical about maintenance, especially washing my vehicles, I do try to stay on top of the mechanical stuff.
I would not worry too much about valve adjustment. This machine has
700-800hr on it and none of the 4300s at the rental place have had their
valves adjusted. If your engine starts to smoke or gets difficult to start,
that is a different story. If the valve lash increases, that should not be a
big worry as these are low-revving engines with low valve spring rates that
will minimize the peening effect (distortion) you can get with a loose
valve train. That is my opinion; hardcore engine builders may disagree.
I AM concerned about potential failure of the air hose. I warned the rental
yard about this problem and I think you should check it out, too. The drain
hose from the fuel filler catchment basin is pinched against the air hose and
I think you can reduce the risk of damage by removing this optional hose.
I hope other JD owners see this (incl 4x10 owners) and check it out.
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 06-30-2009, 02:08 AM   #32 (permalink)
mjncad's Avatar
Thanks for the tip on the air intake duct, I'll be sure to inspect mine even if I have to use a mirror or one of Rigid or Milwaukee's new reasonably priced snake-cams. Another excuse to buy a toy.
__________________
Measure it with a micrometer, mark it with chalk, cut it with a torch, beat to fit, paint to match, inspect it with a microscope.
Google finally fixed Picasa web albums problems I was having. Latest postings.
http://picasaweb.google.com/mjncad/HydraulicsUpgrades#
http://picasaweb.google.com/mjncad/ToolsPower#
mjncad is offline   Reply With Quote
Old 06-30-2009, 04:02 AM   #33 (permalink)
New Member
Bruce-4310TX's Avatar
Il ck my 4310 this weekend, also any chance u could post a good pic of that hood protector i want one to save my new hood. Thanks
Bruce-4310TX is offline   Reply With Quote
Old 06-30-2009, 01:59 PM   #34 (permalink)
dfkrug's Avatar
Quote:
I will do that, Bruce. I do not plan to use my JD hood armor. I happen to
have a 420 FEL brush guard that I am going to use.
Please check your rear axle castings to see if they are Al or steel and post
here. I am very interested in how many improvements JD has made when
they moved to your series in about 2002.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 07-02-2009, 05:28 PM   #35 (permalink)
dfkrug's Avatar
OK, now I am going to drain the hyd oil. I collected about 10 gallons, as
expected.
The first photo shows the main drain underneath the middle of the tractor.
it is connected to the suction pipe/hose that feeds the implement and
power steering pumps. Very accessible, but very vulnerable, too. Not
quite as vulnerable as my Kioti's imfamous low-hanging filter, but there
is no protection from rocks or logs! :-( Anyone break theirs?
The second photo shows my suction filter. It does not look good! It was
not that easy to remove because it was covered with metal fragments,
many more than can be seen here. Something broke inside there, no
doubt. It could not have been sucking very well due to all these pieces...
mostly non-ferrous, BTW. Don't forget to check your suction filter when
doing your 400hr oil replacement!
john-deere-4300-complete-rebuild-oil_drain.jpg  john-deere-4300-complete-rebuild-suck_filter.jpg
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 07-04-2009, 03:27 PM   #36 (permalink)
dfkrug's Avatar
OK, now I am going to open up the range shift/final drive gearbox,
starting with the rockshaft cylinder housing.
After I got all the bolts out, I needed my forklift to get the housing off
the gearbox...it must weight 100lb or so. I plan to completely disassemble
the cyinder, rate-of-drop valve, and position control valve later. The first
thing to do after the top is off is remove the range shift shaft. The shaft is
easily broken off due to the weakness of an O-ring groove cut into it. Mine
is broken as expected. There is a TBN thread posted about this problem
and a well-documented repair....a quick search did not find it. Maybe
someone can post the link here and give credit to the poster?
The 2nd photo shows removing the shifter fork so the shaft can be pushed
out the side of the case. I am using a drift to pound out the roll pin while
I hold a magnet underneath. If the roll pin falls into the sump, it will be
hard to remove. The final photo shows the shaft coming out, and the now
removed shifter fork. The tire has to come off to get this shaft out.
john-deere-4300-complete-rebuild-rockshaft_cyl.jpg  john-deere-4300-complete-rebuild-range_shift.jpg  john-deere-4300-complete-rebuild-range_sh_out.jpg
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 07-04-2009, 04:13 PM   #37 (permalink)
dfkrug's Avatar
Here I am removing the rear PTO cover. Nice big gears in there.
Oh my, look at the pieces of clutch friction disk in there! I picked
out enough fragments for more than one whole disk. There are probably
enough small fragment to fill a 2-oz cup. These are the fragments that
adhered to the suction filter above.
The PTO on this tractor is engaged mechanically and the rental yard has
had a bunch of them broken when the renter engages the clutch at
high RPM with a rotary mower attached. Sometimes the whole clutch
"basket" disintegrated.
john-deere-4300-complete-rebuild-rear_cvr_off.jpg  john-deere-4300-complete-rebuild-pto_rear_cvr.jpg  john-deere-4300-complete-rebuild-pto_clutch_parts.jpg
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 07-04-2009, 05:37 PM   #38 (permalink)
Super Member
kennyd's Avatar
The shaft is
HERE it is...
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is offline   Reply With Quote
Old 07-04-2009, 11:58 PM   #39 (permalink)
dfkrug's Avatar
Oh, yes, it was Richard. Thx for tracking that down , Kenny. I bought
an OEM replacement shaft, mostly due to the concerns of needing a way to
seal the shaft against oil leaks. Poor design, no question.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 07-05-2009, 12:10 AM   #40 (permalink)
Banned
expected.
I've learned a lot by following this thread.
That's a lot of metal fragments in the suction filter.... I have checked mine before and never found no metal.
I still need to check my air intake hose, and thanks for the warning on that!
johndeere4300 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 4.49573 seconds with 9 queries
