arrabil
Mine are tight. I can move them by hand but its very tight.
I'm not seeing it. Both wheels have to be pointed straight ahead with the steering wheel centered and then you have to set the toe-in equally from both ends. I know 1/8" or whatever doesn't matter at these speeds but you can't weld up one side way off and compensate on the other.... the steering won't be centered. No?only one side needs to be adjusted to get the correct toe-in alignment. That means that I could have just welded up one side and used the other side for all the adjustment.
..but you can't weld up one side way off and compensate on the other.... the steering won't be centered. No?
If I remove the boot, is there a square spot on top of the taper shaft to grab the tie-rod with a wrench? I don't want to get covered in grease to discover it was not worth removing it in the first place. I'm having a pain of a time tightening (or rather not tightening) the tie-rod nuts.
