HI,
I recently purchased a Kubota B7100 HST. I think it is a 1996 model. This tractor came with a non-foldable ROPS. I have an orchard that I need to mow and there are lots of tree with a clearance lower than the ROPS. Hence, I would like to remove the ROPS. The ROPS is attached to the tractor by 6 or 8 screws (I did this a few days ago and Imm not home right now), 3 or 4 on each side of the rear PTO. Also, it seems to go through the axle that holds the 2 lower links of the 3 point hitch. I figured the removal would be pretty simple. I removed one wheel and the screws; I removed the pieces securing the ends of that axle; I then removed the 2 lower links of the 3-point-hitch and two spacers from the same axle. I then expected that I could just push the axle out on either side, remove the ROPS, then put everything back. However, I could not get that axle to move at all, in either direction. I figured that it could be hard to remove it if the weight of the ROPS is still on it so I suspended the ROPS to ease the pressure. No change whatsoever. Does anybody know what the problem might be? Am I doing something wrong here? Am I missing something?
Thanks in advance for any advice.
SD
SD
