westcliffe01
Hi folks
I think I did something really dumb... I recently purchased a 2003 Bobcat B200 TLB. It has a diesel Tank on the left hand side of the chassis and the hydraulic tank on the right.
The machine has some small hydraulic leaks which I have not yet tracked down. I think it is primarily related to the power steering and transmission since the leak is worst when at full lock on the steering. Anyway, the sightglass on the hydraulic oil tank is very hard to read and what I thought was the level now appears to be a stain on the level indicator.
This past weekend I put about 50 hours on the machine and right at the end it started jerking (very subtle)a little when going forward or in reverse. All of the other hydraulics work fine (loader or backhoe).
I came to use it Monday and I had the impression it would not move at all. Then I found that if I just kept the hydro pedal down, it would start creeping and finally would build up to normal speed. But as soon as you stop, its the same routine every time.
Thinking that maybe the fluid level was lower than I had initially thought, I bought 4 gal of type 46 Hydraulic fluid and added it to the tank. All of it went in the tank, and there is no change to the sightglass. Since the diesel tank holds about 10 gal, I am assuming that the hydraulic tank has the same capacity and could take at least another 2-4 gal.
So in my mind, the finding appears to confirm the fact that the fluid level became low. The fact that after a delay the machine will operate and build to the same speed as original seems to indicate that I possibly have some air in the system that is causing the problem.
Those of you with some experience, please let me know if I am all wet and something else is going on. In general, does the hydro trans share the same oil reservoir on this machine or does it have its own ? How does one recover from a low fluid situation (does the air have to be bled out ?). And finally, why is it that the hydraulics on the loader and backhoe work perfectly, when the hydro does not ?
Many thanks
Keith
Many thanks
Keith
