Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2002
    Posts
    33
    Default 100 hour service cost
    how much should this be on a Kubota L3010HST?
    thanks
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Mar 2002
    Posts
    45
    Disputanta, Va.
    Kubota L3010HST W/FEL
    Default Re: 100 hour service cost
    I am getting close to mine, and would also like to get an idea of the cost.
  4. #3
    Join Date
    Jan 2001
    Posts
    220
    Central Ohio
    3130HST, Ferguson TO35
    THE 1ST MAJOR SERVICE on a 3010HST is at 50 hours. It requires oil and filter change, hydraulic and HST filters to be changed, HST-hydraulic oil to be changed (10 Gallons), and the oil in the front drive axle to be changed (8-10qts). The HST filter is around $75 as it is a special made filter. Most dealers put in super UDT oil in the front drive axle and transmission and it sells for around $75 for 5 gallons (semi synthetic). A dealer will charge around $400.. I did mine myself and used all Kubota fluids and filters and came to about $225.00.. Some people negotiate this in the price of the tractor when buying. It's not hard to do yourself, you have to be able to catch and get rid of 15 gallons of fluids and the HST filter is hard to remove the 1st time. You need a really large wrench to get the hst strainer out, not crescent.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
