dlabrie
Gold Member
I was using my landscape rake on my B2910. I had the top link extended just about all the way to lift the tines. The wheels on the rake were all the way down. I was going down hill and stopped inches from a tree. When I tried to back up I raised the rake and backed up. The wheels caught the ground. The screw/eye extending from the top link to the rake bent and ripped out of the threaded portion of the top link. I had to hitch a comealong to the ROPS and rake to lift it so I could back away from the tree and head for the garage.
I went to the dealer. They had a generic top link replacement that was a bit larger than the original. Cost $25 verses $125 for a Kubota replacement and X # of days waiting. The end that attached to the tractor was about 1/16 inch too wide to fit. I ground off a little of each side and it works just fine. It came with a bar that appears to slide through the center of the top link to adjust it. It is burled on each end and doesn't go through . Am I suppose to drive it through with a hammer or is there another way it is to be used?
I'll try to send some pictures later today.
David
David
