Results 471 to 480 of 620
01-04-2013, 06:28 AM #471Bronze Member
- Join Date
- Nov 2002
- Posts
- 54
- Location
- Manchester MI.
- Tractor
- Case 530CK
Re: TuffTorq K46 Repair Guide with Pictures
John;
Shurly some one has a spare case to give you, w/all the bad trannys around.
01-04-2013 06:28 AM # ADS
01-17-2013, 11:48 PM #472New Member
- Join Date
- Jan 2013
- Posts
- 2
- Location
- Yorktown, VA
- Tractor
- John Deere L118
So a few pictures from what I found inside. Spent a few nights cleaning it all up. Culprits were the planetary gears inside the final gear along with the axle gears. All were significantly worn with several teeth completely liberated. Pumps, motors and IDS showed extremely minor wear.
Ended up giving my friend JB weld and $30 in new gears from Tuff Torq a shot. Worked great initially two nights ago when I test drove.
But this evening I found a small puddle of very clean 5w50 under the transmission. Found out while I had checked the clearance of my JB patch with the final gear prior to sealing, there is evidently more movement once physcially driving. This caused the final drive to chip away and crack my JB weld. When I resplit the case I could see toward the isnide edges I hadn't sanded enough down and left about 1/8" additional of material.
So now I am wondering if anyone has a bottom casing they don't need? I'll happily send a pre-paid shipping box.....In the meantime I might just try and fix my error. It's either that or the 'Honey Do List'....
Thanks
John
01-25-2013, 07:14 PM #473New Member
- Join Date
- Feb 2011
- Posts
- 5
- Location
- The Deep South
- Tractor
- L17.542 Scotts/JD
Scotts L17.542 / Kohler powered @ 384hrs. / Hot South Florida where the grass grows 24/7
01-29-2013, 01:08 PM #474New Member
- Join Date
- May 2012
- Posts
- 17
- Location
- fallston,maryland
- Tractor
- 1958 JD 620,JD 410 backhoe,scotts L2548
It attaches to the bottom or side of something...... the pump block or motor block....using existing bolts....I have seen it shown in parts diagrams within this post.....just look back on one of the 48 pages.
01-29-2013, 01:44 PM #475New Member
- Join Date
- Feb 2011
- Posts
- 5
- Location
- The Deep South
- Tractor
- L17.542 Scotts/JD
01-29-2013, 03:39 PM #476New Member
- Join Date
- May 2012
- Posts
- 17
- Location
- fallston,maryland
- Tractor
OK.....make sure the gear shafts are in correct place....I screwed up mine when the cover went back together....I might have spun the axle shafts which causes the gears to climb out of position during bottom cover install.
02-03-2013, 12:18 PM #477New Member
- Join Date
- Jan 2013
- Posts
- 1
- Location
- willow street.pa
- Tractor
- John Deere LA120
Thanks Joebob,
I have a 2007 LA 120 (JD) and had same transmission slippage when hot (15 min.)! Started with less than 100 hours and tore apart at 160 hours. Found scoring as JOEBOB described and took a chance and got center case, motor cylinder, and pump cylinder mating surfaces milled down approx. 3 mil. to remove scoring. COST $32.5 Pre-loaded cylinders with Mobil 1 15w-50 reassembled, filled with 15w-50, installed tranny, performed tufftorq air purging procedure, removed tranny to check fluid level (had to add some), reinstalled tranny, crossed my fingers and; voila, ran like she was brand new! One thing to note is that it's February and only ran for 5 minutes but had a lot of jump when accelerating from a dead stop and did not notice the whine when going up steep hill. THE TRUE TEST WILL BE THIS SUMMER WHEN TEMP'S ARE HOT AND 1 HOUR RUN TIME. I'll do my best to update this summer. Thanks again Joebob and LotsofGreenGrass and others for all the posts! Never tore a tranny apart before but found it relatively simple with all the pictures, diagrams, and posts!
THANKS, SHANE
LANCASTER PA.
02-07-2013, 08:45 AM #478Bronze Member
- Join Date
- Nov 2009
- Posts
- 79
- Location
- Gallatin, TN
- Tractor
- John Deere L110 and Mahindra 2816 4wd
Could have it patched with a braze or weld possibly.
02-07-2013, 08:49 AM #479Bronze Member
- Join Date
- Nov 2009
- Posts
- 79
- Location
- Gallatin, TN
- Tractor
To all. I apologize if you have left a message for me and I have not replied. Apparently, I am not getting message notifications.
02-09-2013, 05:38 PM #480New Member
- Join Date
- Jan 2013
- Posts
- 2
- Location
- New bern N.C.
- Tractor
- Craftman 21hp lawn tractor
LotsofGreenGrass,
I would like to THANK YOU for your writeup with the EXCELLENT pictures.I followed your writeup and repaired my K46 Trans axle,and it is working fine.Without people like you and this great forum,we would be paying alot for these type of repairs.Would also like to thank the people at Tuff Torq [Derrick Dolain] for all there HELP they were GREAT.
THANKS AGAIN,Lotsofgreengrass
Ed
Similar Threads
"Floating" deck guide wheels -- anyone make theirs bigger, or swivel?
By jas67 in forum Kubota Owning/OperatingReplies: 13Last Post: 05-31-2009, 08:50 AM -
JD Owning/Operating FAQ (Please Help)
By Muhammad in forum John Deere Owning/OperatingReplies: 42Last Post: 02-08-2009, 10:38 PM -
cub cadet panel repair
By harleyizy in forum Parts/RepairsReplies: 8Last Post: 12-12-2008, 12:49 AM -
Pictures, Pictures
By ddl in forum News/FeedbackReplies: 9Last Post: 11-17-2001, 08:35 PM
