Hi again,
again, thanks for the information in
post 590, Voyager6!
I'll be looking for a K58H now for my 70s John Deere that's awaiting restoration. Great info!
Parts I would need to make this transmission good-as-new again would be way over 500€, so I'm not going full monty on this, only replace the absolute necessary, clean everything and adjust all the clearances.
I have sent an email to Derrick asking if there is a steel version of differential gears for the K46. He just replied, but there is none. So I'll stay with the sintered differential gears and order them now (along with the axle bushings, which are cheap).
Speaking of which: I was trying to shim out the gears today (and will have measurements soon), but was unable to do so with the differential gears. No matter what, the final drive gear is too wide to let the pinion gears ever get in full contact with the side gears. They can always move about way too much. I will wait for the new parts and see if they fit better, else they will have to be ground down to get tighter together.
I'm still completely lost why there's so much play by design in there.
I also sanded down the wear of the center case with 1200 mesh paper, then gave it a little polish. Looks good now! Great idea. Yes I left a barely visible ring on the pump side, but I lost motivation.
Also, a tiny bit of roughness is good to keep an oil film on.
The underlying surface I use for my sandpaper is glass out of an old (as old as possible!) computer scanner. They're reasonably thick and of perfect flatness, and free. I didn't sand the pump or motor, but carefully deburred the edges of their kidney ports with an oilstone. Maybe this helps in not eating up the center case faces.
I tried to remove the two valves from the center case with a neodymium magnet and some strokes with the back of a screw driver. They came out no more than 1.5mm and had scratches, looking down into the center case. So I pushed them back in, still unsure of their function or if they even should come out.
Will keep you posted...
Good luck with the lawsuit, it's a joke JD sells this unit with no way to service. Glad my K46AM did not come with a JD.
Greets,
Stefan
