diggler1971
- Joined
- May 31, 2009
- Messages
- 1
So, I've read all these posts and watched a couple videos before tearing into my son's L110 mower transaxle. What I'm trying first is thorough internal cleanup and machining (sanding) the pump and motor and there corresponding mating surfaces on the center case. That all went well and the parts all smoothed out nicely. Although it took a good bit of sanding with 400 grit sandpaper and cutting fluid. I have it back together on the bench and I'm waiting for a new filter and filler cap. My question regards the oil to put in the unit. I was going to put mobil 1 5w-50, but I can't find it locally. In fact, I can't find anywhere local that has any brand of synthetic 5w-50. I can, however, get mobil 1 15w-50 locally. I'm thinking that the difference is negligible from 5w to 15w, as it's at the cold viscosity end of the oils capability and he won't use this mower in cold weather anyway. Am I wrong on this, or is the 15w-50 "close enough"?
