HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Parts/Repairs
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-14-2002, 07:50 PM   #11 (permalink)
Default Re: Broke my BH
Maybe the cylinder is defective in some way, take it to the shop and ask. it seems you may not be the only one this has happened to and just maybe you will get a new one for free. it does not hurt to ask. not sure why these would bend from normal use unless it was hit from the side somehow.
Steven is offline   Reply With Quote
Old 08-14-2002, 09:20 PM   #12 (permalink)
Boy if those prices are even close to right on such a small (pretzel size) stinking cylinder then I'm in the wrong business. Man that just tee'd me off big time thinking how they are robbing people and they call it legal. I have replaced a cylinder off a unit I use to own and it was double if not triple the size and it was less than $200 with shipping which was a good chunk of change because they are so heavy. Well please let us know for future reference if you find out. Talk later
Darin
DarinRay is offline   Reply With Quote
Old 08-14-2002, 10:32 PM   #13 (permalink)
I still think there were some issues with the hardening process on some JD backhoe cylinders that were replaced under warranty. But I just can't seem to find the threads that were discussing it.
Kodiak is offline   Reply With Quote
Old 08-15-2002, 12:11 AM   #14 (permalink)
db4700,
It wouldn't hurt to see if some sort of warrenty will cover the cylinder.
But if it doesn't and John Deeres prices are that high for a replacement(which I'm sure they are !).
An aftermarket could probably be found for under $150.
DK35vince is offline   Reply With Quote
Old 08-15-2002, 11:20 AM   #15 (permalink)
That was the post, I forgot to highlight the text, as I was running out of work at the time. Here is the link to he actual posting: <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&amp;Board=jdown&amp;Number=43 150&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1#Po st43150/>BROKEN HOE</A> Read the 2nd to last post from Chris to see the resolution. This person had JD cover the repairs under warranty, if you bought the Hoe new from a dealer I would not pay for the repair yourself, this is a common problem. Hope this helps, Jason
jasonf is offline   Reply With Quote
Old 08-15-2002, 03:53 PM   #16 (permalink)
I went back out to my land today to pick up my tractor and take some pictures of the backhoe to take to the dealer. It looks a lot like the cylinder in the post you identified and some others. I hope I can get it covered under warranty since it should not have bent under the power of the backhoe itself.
db4700 is offline   Reply With Quote
Old 08-15-2002, 03:55 PM   #17 (permalink)
View of the bent cylinder.
Old 08-15-2002, 03:57 PM   #18 (permalink)
Another view.
Old 08-15-2002, 04:04 PM   #19 (permalink)
I'd push hard for the warranty fix. No way you should be able to bend the rod that way. Looks like they undersized hydraulic cylinder based on the psi your pump is pushing OR have the releif valve set too high. Somethings mismatched. If you pull/push against an immovable object you should just blow by the relief valve. WORST case scenario maybe you blow a hose or fitting. I'd be a pretty unhappy camper with JD if I were you.
gerard is offline   Reply With Quote
Old 08-15-2002, 06:48 PM   #20 (permalink)
That was my thought. The pressure relief valve should have opened long before that shaft started bending. I would make sure the shop checked the operation of that valve and would definitely try to force a warranty repair.
Ozarker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
