Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    2
    Default snapped the rear pto on my JD 2305
    I was tilling my garden and after the loud bang I got off my tractor looked at the rear PTO only to see the fluid pouring out where the shaft had snapped off. I am a little nauseous. Can one replace the shaft by yourself and how much will a new shaft cost?
  2. #2
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,129
    Windham, NH and York, ME
    Kioti LK3054xs TLB, 2004
    Default Re: snapped the rear pto on my JD 2305
    HI, where you live?
    You are likely going to need to tear down the majority of the rear end to get to where the shaft is keyed, clipped or pinned in.
    Likely a good amount of work.
    Did your slip clutch fail?
    Hopefully nothing else got munched up.
    I'd not operate the machine until you sort it out.
    Joel
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    King Cutter Tiller
    Three Point Snow Blower
    York rake
    60 inch king kutter tiller
    2000 Dodge Durango 5.9
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Its going to require some work as said before. The 2305 is a fairly new tractor. Is it still under warranty? Either way if you are not a mechanic its probably a job for the dealer which is going to equal $$$$.
    This is not the first time this has happened to the JD 2300 series. Looks like its a weak spot.
    http://www.tractorbynet.com/forums/j...-take-off.html
    Chris
  4. #4
    New Member
    Join Date
    Apr 2010
    Posts
    2
    Upstate NY
  5. #5
    Gold Member davkir's Avatar
    Join Date
    Sep 2005
    Posts
    370
    Hendricks Co., In
    JD 2305 W/CC & R4
    Hope this helps.
    Attached Thumbnails Attached Thumbnails snapped the rear pto on my JD 2305-pto-251-jpg   snapped the rear pto on my JD 2305-pto-252-jpg   snapped the rear pto on my JD 2305-pto-253-jpg
Similar Threads
  1. L2800-L3400 PTO Making the right choice
    By 8226hamer in forum Kubota Owning/Operating
    Last Post: 03-24-2016, 07:26 AM
  2. TC33D Rear PTO Shifter
    By GAFAQ_33 in forum New Holland Owning/Operating
    Last Post: 07-18-2008, 09:04 AM
  3. PTO shaft fun facts...
    By Rara Avis in forum Safety
    Last Post: 04-08-2008, 10:13 PM
  4. John Deere 2520 - Rear PTO & Rear Implement Shaft Overlap
    By larry8818 in forum John Deere Owning/Operating
    Last Post: 08-27-2007, 03:17 PM
  5. Rear PTO light
    By bosshoss in forum New Holland Owning/Operating
    Last Post: 06-06-2007, 11:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
