Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    1
    Default White Field Boss 31 (Iseki) ignition switch
    I think the ignition switch on this 1980s compact diesel tractor has failed. Anyone got a source for a replacement?
    There's no part number on the switch. It has four positions=off, on, glow and start= and five terminals on the back. The glow and start positions are spring-loaded. The terminals are numbered 30 (power from battery), 17, AC, 19 & 50. I think the 50 goes to the glow plugs. In the ON position and the START position, there's intermittent continuity between the power terminal and other terminals. Seems to be pretty good continuity to the glow terminal.
    Can anyone suggest a replacement switch?
  2. #2
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,504
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Default Re: White Field Boss 31 (Iseki) ignition switch
    "Can anyone suggest a replacement switch? "
    Sorry no help w/replacement number..but these folks have done real good for me getting parts.
    Tech will help also fax info.
    White Dealer
    Swanton,VT.
    1-802-868-4050
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    18
    mi
    white field boss 31
    wanted to know if you found one? im in need of one to thanks!
  4. #4
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    If my memory serves me correctly that sounds like the numbering on a kubota B7100 switch. I don't have one in front of me as I am at work now. If I remember I will check when I get home. I have a spare switch (If I can find it)
  5. #5
    Join Date
    Jul 2005
    Posts
    1,752
    Linden VA
    yes that sounds like that kubota switch. i just replaced the key switch on my ford 1710 with it. same terminal markings. i got mine from a place called weaver parts.
  6. #6
    New Member
    Join Date
    May 2012
    Posts
    18
    mi
    white field boss 31
    That would be great ! Let me know thanks
  7. #7
    New Member
    Join Date
    May 2012
    Posts
    18
    mi
    white field boss 31
    Hey k s did u get a chance to look for that switch?
  8. #8
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Sorry- Been real busy and forgot. I will write myself a note to look when I get home tonight.
  9. #9
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    OK-- found the switch
    17,19,30,50 and AC
    Quick look at my service Manual
    19 to glow plug indicator then to 17
    17 to glow plugs
    50 through the safety switch then to starter
    30 multiple connections must be power in from battery
    AC out to lights and hour meter (accessory)
    Sounds like the same switch you have on your tractor.
  10. #10
    New Member
    Join Date
    May 2012
    Posts
    18
    mi
    white field boss 31
    hey KS thank you for your time and help !
Similar Threads
  1. TC29D Ignition Switch Replacement
    By TC29D in forum New Holland Owning/Operating
    Last Post: 02-15-2018, 08:15 PM
  2. White Field boss31=what Iseki model
    By Anonymous Poster in forum Iseki
    Last Post: 08-02-2010, 10:35 AM
  3. Ford 1715 ignition switch
    By shyguy6 in forum Parts/Repairs
    Last Post: 10-04-2006, 11:57 PM
  4. Kubota B6100 ignition switch question
    By txdave05 in forum Parts/Repairs
    Last Post: 01-17-2005, 08:35 PM
  5. weird house wiring problem
    By Mosey in forum Related Topics
    Last Post: 03-28-2002, 07:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
