Results 1 to 10 of 10
  1. #1
    Member
    Join Date
    Jun 2009
    Posts
    28
    Default testing relays
    How are electrical relays tested? I have a JD 4300 and I suspect that there may be a bad relay preventing the engine starting (won't crank when the key is turned). Thanks!
    --Karl
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,048
    Central Ohio
    Kubota MX5100
    Default Re: testing relays
    Quote Originally Posted by kak View Post
    --Karl
    There are several types of relays but the most common are the little ice-cube relays. About 1.5" square and have 4 terminals. I'll assume you are talking about them.
    The terminals are usually labled 85, 86, 87, and 30.
    85 and 86 is the control side of the relay and create a magnetic field to close the "switch" between terinals 87 and 30.
    The easiest way to test is to check for continuity between 87 and 30. There sould be none, or the switch open.
    Then add 12v to 85 and ground 86 and see it the continuity between 87 and 30 goes to 0 ohms (switch closes).
    Some relays have an 87a terminal which is a normally closed terminal. meaning it has power (continuity with 30) without 85 and 86 having power and ground, and opens (no continuity) when power and groung are applied to 85 and 86.
    Additionally, some relays are controlled with the ground wire on 86 and otherswith the 12v on 85. Depending on your tractor, it may have 12v all the time on 85 and when you what to enetgize the relay, in closes the switch and allows 86 to ground. Others have 86 grounded all the time and when the relay needs to be energized, it supplies 12v to 85.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    Join Date
    May 2009
    Posts
    1,616
    Dont know about Deer, but most starter motors have a solenoid that does two things;
    First there are heavy duty contacts that carry the 200+ amps that run the starter motor.
    Second, the solenoid slides a gear along the starter motor shaft that engages with the flywheel ring gear to spin the engine.
    The relay that you refer to may be the switch that sends current to the solenoid.
  4. #4
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,868
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Relays are pretty simple. The coil must be energized for the contacts to actuate. However, depending on how one is designed, it will have either NC (Normally Closed) or NO (Normally Open) contacts. The ones that are NC you should measure near zero ohms across the contacts with no voltage applied to the relay. When the coil is energized, NC contacts should read infinite resistance (open).
    For NO contacts, they will measure infinite resistance with the coil de-energized. Once the coil is energized, they should read near zero ohms through them. Oftentimes a relay will have both NC and NO contacts.
    The contacts can become corroded over time, especially in humid environments or if they have poor weather sealing. They can also become burned due to arcing over being closed or opened during many cycles of operation.
    The coil itself can open up (near infinite resistance measured across it) which means it will not energize. Or, it can have shorted turns (lower resistance than it should measure), this condition may or may not let it energize. The only way to know the proper dc coil resistance that you should measure is to have another known good one (same type) to compare with, or have the manufacturers spec's to it handy to refer to.
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  5. #5
    Join Date
    Dec 2005
    Posts
    226
    SE PA
    bx1500
    I don't think most tractors have the "ice cube" relay involved in the starter circuit, but LD1 explained that nicely if you do have one. Make sure your battery is good. You should have 12.6 volts to begin testing. Find your starter and unplug the small wire at the solenoid. Check to see if you have 12v supplied to it while ignition key is in the crank/start position. If you do, make sure your big wire at the solenoid has 12v, and a good clean connection. If you don't have 12v at the small wire when attempting to start, you need to work backwards through the wiring to find out why. Safety switches on seats or ptos or transmission linkage could be involved.
  6. #6
    Veteran Member KB9UDE's Avatar
    Join Date
    Apr 2006
    Posts
    1,058
    North of Tower Hill, IL
    John Deere 3320
    I am also thinking it could be a safey switch
    John
    John Deere 3320 - 72D Auto Connect deck
    Acts 2:38
  7. #7
    Elite Member mostly_gas's Avatar
    Join Date
    Sep 2009
    Posts
    3,759
    Texas
    in-between tractors
    And be careful about whether the safety switch is normal closed or normal open. I had real fun with a Rx75 until I worked out the seat switch is normal closed. (to by pass the switch simply unplug).
  8. #8
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,663
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Karl, here is a photo of your fuse panel. Hopefully yours is cleaner. Most
    if not all of your relays are the same kind (well-described by LD1). You
    can swap the relays around to test them, as well as using an Ohm meter
    and a battery. I do suggest that you look at the electrical diagram to see
    what each one is for. Also the various safety switches are more likely
    your problem, vs the relays.
    Since these are standard plug-in automotive relays, you don't have to
    get them from Deere. I used Bosch units for my replacements.
    Attached Thumbnails Attached Thumbnails testing relays-fuse_panel-jpg
  9. #9
    Join Date
    Jun 2004
    Posts
    1,368
    N.E. KY
    Century 3035
    Quote Originally Posted by LD1 View Post
    This page has a diagram and pictures of the type of relay LD1 describes. Basic Wiring - Custom Airbrush Work and Radical Customizing
    Here is another simpler diagram of this relay
    Century 3035, FEL, RC, RFM, Box Blade, Pond Scoop, Boom Pole, Hay Spear
  10. #10
    Join Date
    Mar 2001
    Posts
    214
    Burlington, Kansas
    NH TC33D
    This may or may not help. I'm guessing you are thinking one of the relays aren't working. Maybe you need to check your ground. My NH was having starting problems, after replaceing several parts- some were relays - I removed the grounding cable at the frame - It look good, but the back side was really bad. After sanding the cable back and the tractor frame contact point - and reinstalling on the tractor it now starts just fine.
    TC33DA, Kawasaki 650i atv
Similar Threads
  1. Testing a PT 400 & 200 monday
    By Landwise in forum Land Clearing Equipment
    Last Post: 08-28-2008, 08:07 PM
  2. Engine oil testing????
    By Kays Supply in forum Oil, Fuel & Lubricants
    Last Post: 01-02-2008, 05:52 AM
  3. Nebraska tractor tests and comparisons in the news
    By kybota in forum Buying/Pricing/Comparisons
    Last Post: 02-25-2005, 02:49 PM
  4. Testing New digital Camera
    By Rowski in forum Photos
    Last Post: 06-28-2001, 01:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
