collard king
Well since last time I posted about steering problems. I have changed the filter in sterring pump, which was super nasty! Thanks for the info on that. I removed the tie rod ends, the left side was trashed!!! Believed this could be causing the drag i was feeling. No luck... with the tie rod ends unhooked, there is still a drag or hard spot in the steering when i turn right. I would know believe the problem is now in the column.
Has anyone had this kind of problem with a ford tractor. I would like to have some ideas on where to start. Thanks for all info you guys provide.
