Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member massey driver's Avatar
    Join Date
    Aug 2009
    Posts
    449
    north of winnipeg canada
    massey 175,1655 BX 2370-1
    Default Making your own snowblower shear pin/bolt
    After buying a few shear pins for the snowblower and paying way to much I decided to make my own.I made a jig out of a piece of 1/4" pipe and a piece of angle iron.I welded the pipe to the angle iron placed the new shear pin/bolt beside the pipe to mark where to cut the slot.I then put the shear pin/bolt into the pipe and cut down into the pipe untill the hacksaw blade just made contact with the shear pin/bolt.I did that for both slots.I then used my drill to spin the bolt and just held the hacksaw in the pre cut slot's untill the slots where cut into the bolt.I made 10 of then in a few short minutes.Now I won't feel Like I'am being taken for a ride when I need to have a new shear pin/bolt. Larry
    Attached Thumbnails Attached Thumbnails Making your own snowblower shear pin/bolt-shear-pin-jig-1-jpg   Making your own snowblower shear pin/bolt-shear-pin-jig-2-jpg   Making your own snowblower shear pin/bolt-shear-pin-jig-3-jpg
    Massey Driver Larry
    MF 175 Diesel, BX 2370-1 Diesel,
    Still enjoy driving my tractors and making them work laughing:
  2. #2
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    Default Re: Making your own snowblower shear pin/bolt
    What grade of bolt do you use to give the same protection level as the regular shear pin?
  3. #3
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    That's a great idea Massey Driver.....
    I checked a new package of Ariens 5/16-NC shear bolts and they don't have the usual notches/markings of grade 5 or 8 hex bolts......so maybe they're grade 2 or less..??....Yes/No..?
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  4. #4
    Super Member
    Join Date
    Aug 2004
    Posts
    6,481
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    I use plain bolts for my shear pins.
    Grade 5 as they shear nice and clean
    The hardware store grade is simply mild steel and they burr B4 shearing and become a bear to drive out and as well they elongate the mateing pin holes.
    I always use nylon lock nuts torqued nice and snug.
    No problems going on 6-7 years now and probably go thru 24 a year on both the auger and impeller each.
  5. #5
    Join Date
    Aug 2009
    Posts
    449
    Quote Originally Posted by pat32rf View Post
    Quote Originally Posted by wdchyd View Post
    Same on both blowers that I have 48" snapper and 48" ariens I'am using grade 5 with the notches cut into them.The cut in notches make them the same as a 1/4" bolt.I've sheared the grade 5 bolt 5/16" on the ariens without the notch[piece of firewood] but to be safe have decided to use the notched ones now.The bolts are cheap compared to having problems with the gear box etc:The grade 8 bolts would be just to tough.Basicially its like just using a 1/4" bolt with having that notch cut into them.Thats where there going to shear off.Larry
    Massey Driver Larry
  6. #6
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Do your blowers' manuals call for Grade 5 or better shear bolts?
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  7. #7
    Join Date
    Aug 2009
    Posts
    449
    Quote Originally Posted by mjncad View Post
    Don't have manuals for either of them I just use Grade 5 This is what I do!!!! So what you do is up to you.Just posted a way to make your own if your inclined to do so.Larry
    Massey Driver Larry
  8. #8
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    Just curious Larry. My Bush-Hog calls for Grade 2 shear bolts and that's what I use.
  9. #9
    Join Date
    Aug 2009
    Posts
    449
    I don't have any manuals for mine I figure that using a grade 5 would be the best way for me to go with the notches cut into them as the grade 5 will shear off and not tend to want to bend etc: like mild steel.Larry
    Massey Driver Larry
  10. #10
    New Member
    Join Date
    Nov 2010
    Posts
    1
    Massey_driver,
    Thank you very much for taking the time to share this and providing photos. Excellent tool and instructions. Another way to be self-sufficient.
Similar Threads
  1. Post Hole Digger Shear Bolt question
    By nspec in forum Attachments
    Last Post: 09-21-2010, 01:43 PM
  2. Heads up for 47" snowblower users..
    By ChuckinNH in forum John Deere Owning/Operating
    Last Post: 05-06-2009, 09:15 PM
  3. Need a shear assembly for my PTO shaft
    By fish6942 in forum Attachments
    Last Post: 11-30-2007, 05:21 PM
  4. Snowblower Snowblower Results
    By BXRICK in forum Attachments
    Last Post: 03-20-2007, 07:27 PM
  5. SNOWBLOWER SHEAR PINS
    By ric in forum General Lawn & Garden
    Last Post: 02-26-2003, 09:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
