Results 1 to 10 of 18
11-08-2010, 02:42 PM #1Gold Member
- Join Date
- May 2006
- Posts
- 267
- Location
- Austin, Texas
- Tractor
- Kabota 7500DT
6 Volt Gator, 12 volt TSC spray pump ?
Hi folks, I got a TSC 25 gallon sprayer on sale and didn't realize it has a 12 VDC pump and my Gator electrical system is 6 VDC. Any suggestions how to make my sprayer pump work off the Gator system ? Or any suggestions on a replacement 6 VDC pump- model and source ? Tnx.
BobFarmer Bob
Kubota 7500DST w/FEL,box blade,posthole digger,brush hog
11-08-2010, 02:56 PM #2
11-08-2010, 04:10 PM #3Veteran Member
- Join Date
- Sep 2002
- Posts
- 2,010
- Location
- Michigan
Re: 6 Volt Gator, 12 volt TSC spray pump ?
You could pick up a 6 volt golf cart battery and wire it in series with the existing battery to power the pump. You'd need to charge it with a battery charger when it runs low.
11-08-2010, 04:51 PM #4
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
11-08-2010, 04:54 PM #5
11-08-2010, 04:59 PM #6Veteran Member
- Join Date
- Dec 2003
- Posts
- 1,693
- Location
- NC
- Tractor
- Kubota Grand L3830
This is the only 6 volt Gator I have ever seen. John deere Utility Tractor 6 Volt by Peg Perego
11-08-2010, 05:15 PM #7
Convert the Gator to 12v.
Buy a 2nd pump and run them in series at 6v apiece.
Buy a 6v pump.
Buy an up-converter to produce 12v from 6v.
Buy a new Gator.
6v battery is best idea. Charge it very few years.There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
11-08-2010, 06:06 PM #8Veteran Member
- Join Date
- Sep 2002
- Posts
- 2,010
- Location
- Michigan
11-08-2010, 06:07 PM #9Veteran Member
- Join Date
- Sep 2002
- Posts
- 2,010
- Location
- Michigan
11-08-2010, 07:13 PM #10
John Deere 4110HST
Similar Threads
12V Sprayer pump.
By TCowner in forum AttachmentsReplies: 3Last Post: 04-06-2011, 05:59 PM -
Sprayer 12 Volt Tow-Behind Sprayer
By pintodeluxe in forum AttachmentsReplies: 2Last Post: 08-02-2009, 10:54 PM -
Sprayer Yard Sprayer Questions
By robertm in forum AttachmentsReplies: 4Last Post: 06-12-2009, 11:01 AM -
on-demand pump problem
By woodlot in forum Rural LivingReplies: 8Last Post: 06-28-2006, 05:02 PM -
Sprayer with 12 volt pump
By Briarwood in forum Kubota Owning/OperatingReplies: 8Last Post: 05-30-2003, 01:49 PM
