Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Dec 2010
    Posts
    2
    mahindra 5500 4wd
    Default 3 point hitch wont stay lift
    I've had a 2005 Mahindra 5500 4wd since it was new. It's been a true workhorse! Recently the 3-point hitch quit staying in the "up" position unless the throttle is revved. All fluids and filters have been properly serviced throughout its life, and control valve assembly has been disassembled, inspected, and seals replaced subsequent to this problem. That repair attempt didn't change my problem: it will only stay in the "up" position when the throttle is kept revved. Any ideas as to what else it could be?
  2. #2
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,857
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Default Re: 3 point hitch wont stay lift
    Does it have a loader? If yes, do all the loader functions work normally?? If yes, then probably the hydraulic pump is probably ok.
    If you don't have a loader, I would get a pressure gauge and check the hydraulic pressure, maybe the pump is getting worn/weak? The service manual should tell you where/how to check it, and what you should measure. Good luck.
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5ft King Kutter II Rototiller, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Look for hyd cylinder leaking, a relief valve sticking, an unloader valve sticking, valve leaking. If you install a hyd gage, you should be able to trouble shoot your hyd system. You should have full pressure when the 3pt valve is in relief mode.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,630
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    flow rate check would help too. that and the pressure check will tell you alot.
    soundguy
Similar Threads
  1. 2 point to 3 point hitch
    By lstork in forum Attachments
    Last Post: 02-10-2013, 09:36 PM
  2. 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
    By JOHNTHOMAS in forum ATVs & Utility Vehicles
    Last Post: 06-06-2011, 12:32 PM
  3. Replies: 24
    Last Post: 09-27-2010, 06:20 PM
  4. Kubota M5700 3 point hitch wont go up
    By az6930 in forum Hydraulics
    Last Post: 08-03-2010, 08:58 PM
  5. Three point hitch lift arms not working
    By mchild in forum Parts/Repairs
    Last Post: 11-15-2005, 10:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
