Results 21 to 24 of 24
03-01-2011, 12:29 PM #21Elite Member
- Join Date
- Sep 2010
- Posts
- 2,972
- Location
- 35 miles North of Memphis,TN
- Tractor
- kubota L3000dt, ford 8n1952
Re: Lets talk BATTERIES (12v starter batteries)
Don't forget the obvious, the cables that hook it all to the tractor. Small guage, or frayed connections on cables rob all that cranking power, before it reaches the solenoid. Old solenoids should get very hot as the resistance builds up, and the current flows thru it. Not to say the new compact solenoids don't get hot when they are new, as per the new engineering..build it cheaper and faster and more compact?
Okay, Legal disclaimer: Old but not senile, definitely do not have the answer to everything!
03-01-2011, 10:47 PM #22
Racerboy.....I'm intrigued....
My Kubota glowplugs are heated when I first turn on the ign switch but the yellow light goes out within about 3-6 seconds. This leads me to believe that they are no longer taking current.
What is different about yours and WHAT did you do about it? You say it spins fast without the GP's.....HOW did you disable them? and does it START well without them?
03-02-2011, 03:17 PM #23Silver Member
- Join Date
- Aug 2010
- Posts
- 166
- Location
- Connecticut
- Tractor
- Deutz Allis 5220 w FEL and Backhoe
You Prolly have some more Hi tech system. My plugs work when I go left with the Key. They are also wired so that when you put the key to start they have power. All I did was make it so when I turn the key to the left it powers the plugs, I took the jumper off so when I turn it to the right there is no power to the plugs. The time it takes to turn the key from left to right this plugs are still glowing so I needed the extra power to the starter solenoid. If you google tractor starter improvement kit. You will come up with a relay kit that basically make sure full batt voltage go to the starter solenoid through the relay. It's a common problem with tractors due to all the safety switches. Mine starts like a champ cause it spins at twice the speed.
03-02-2011, 08:09 PM #24
WOW, that would be an improvement. What kind and age is your tractor? mine is 11 years old now.....Kubota
Similar Threads
Neat starter design
By Chuck52 in forum Parts/RepairsReplies: 6Last Post: 04-03-2004, 10:45 PM -
solenoid
By Tinkerer in forum General Vintage TractorsReplies: 19Last Post: 02-17-2004, 08:58 AM -
Jump-Starting a Ford 801
By Mrwurm in forum Ford Vintage TractorsReplies: 3Last Post: 12-02-2003, 10:11 PM -
Case 448, 18 hp Onan, needs new starter.
By Anonymous Poster in forum Parts/RepairsReplies: 18Last Post: 04-26-2003, 10:31 PM -
US Postal Service Commercial
By DaveNH in forum Related TopicsReplies: 25Last Post: 10-18-2001, 08:19 AM
