Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Feb 2011
    Posts
    2
    Hartland, Wisconsin
    John Deere 445
    Default John deere 47 inch snowblower Drive Chain
    Looks like I broke the drive chain. How do I access it and can I replace the chain myself?
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,921
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: John deere 47 inch snowblower Drive Chain
    A search should come up with some threads on changing out the drive chain. Look at it closely to see where the bolts need to be removed to get at the chain and drives.
    Some pics will help us point the finger where to start. I'll see if I can dig up a thread or two to help.
    Here is the one I'm thinking of.
    http://www.tractorbynet.com/forums/j...ets-chain.html
  3. #3
    Join Date
    Dec 2008
    Posts
    898
    Buffalo, New York
    318 John Deere, 4200 John Deere, 1947 John Deere "M"
    Welcome to TBN! But I do wish that newer members would give us at least a brief profile! Like where you are, State, Town, and the tractor and equipment numbers!! There lots of people here that can almost "walk-you-through" the repair, and have search capabilities, that you may not think of. Some of the JD Exploded drawings cannot be of help, without the specific 'Blower-Thrower' model number!! My experiance has been that I buy #50 roller chain, and a master link, and with three bolts to remove, and loosing an idler assembly, this should be an easy fix........~Scotty
  4. #4
    New Member
    Join Date
    Feb 2011
    Posts
    2
    Hartland, Wisconsin
    John Deere 445
    It was the chain drive on the blower unit. Found hooking up the new chain to be a little difficult. Not a lot of room for holding the chain and attaching the clips once I got it on the gears. Also, I took off the yellow guard above the drive off to gain easier access. Did not realize that with the coil wire acting like a spring, it would be difficult getting it back on . Not totally sure if I have it back in the right place, but it does not come in contact with the drive so that is good. Thanks for the info. Rich
  5. #5
    Join Date
    Dec 2008
    Posts
    898
    Buffalo, New York
    Rich- I've got a 48" single stage "thrower" as opposed to your 2-stage blower unit. They probably both use #50 roller chain, (But that's a guess!). My unit doesn't have a spring loaded tentioner. Sounds like you've got this job pretty well wrapped up! I've found that counting the links so that replacement has the same count, and lining up the master link on a spot on the large sprocket is the way to go. Then it's just a matter of replacing the master-link, and reconfigure the tensioner! If you need any further help, 'yell'! Thanks for the updated profile! ~Scotty
Similar Threads
  1. John Deere 2305 Compact Tractor Transmission and rear PTO failure
    By JBarnes6767 in forum John Deere Owning/Operating
    Last Post: 04-18-2017, 12:44 AM
  2. John Deere snowblower starter.
    By radiowaves88 in forum Parts/Repairs
    Last Post: 07-14-2010, 08:26 AM
  3. front mount snowblower drive chain what size?
    By 600rider in forum Parts/Repairs
    Last Post: 03-01-2010, 08:02 PM
  4. Snowblower John Deere 3 point snowblower
    By Tritonman in forum Attachments
    Last Post: 03-28-2008, 09:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
