sunspot
Gold Member
I have a cracked power steering line. It goes from the right side hydraulic ram to a block on the steering column. How can I tell the difference between the feed side and the return side?
It's about a $30 part, so I don't want to buy em both if I can help it.
The tractor is a 1986 Ford 3910.
At the ram, it's the upper line. Up on the steering shaft, it's the inside line.
If it helps, the crack is on the flare. I do not have a flaring tool.
