machmeter62
- Joined
- May 24, 2004
- Messages
- 638
I maybe guilty of leaving the fuel in the tractor too long after the mowing season in Calif.? I also put fresh fuel in it before attempting to start it. It won't start without starting fluid, then quits after the fluid expires. The fuel line is clear all the way to the carburetor, but I suspect the float is stuck inside the carb. that is preventing the engine from continuing to run?
The carb. is very difficult to get at without removing/unbolting a large section of the front of the tractor. I have tried tapping the float assembly with a fiber hammer/extension only, with to no avail of un-sticking it? After two cans of starting fluid, do you gentlemen have any other solutions? With all the additional polution hoses/vapor barriers, etc. I may have to take it to a Sears Service Center? Thanx in advance for your thoughts.
