Results 1 to 7 of 7
07-26-2011, 06:41 AM #1New Member
- Join Date
- Jul 2011
- Posts
- 14
- Tractor
- Case 580C(198?)
Case 580C won't shift
Hey guys, I'm shopping for a backhoe. I called about one today that isn't running at the moment. The current owner says it was parked about a year ago. He said that it wouldn't shift unless they took the top of of the transmission and moved things around to get it to go. He thought the syncros might be bad. Does anyone have any idea what is wrong. Hopefully it's an easy fix. I'm currently deployed to Iraq and I'm planning to have a friend go and get it for me. Just want to make sure I'm not biting off more than I can chew. I'm am a mechanic by trade but I've never worked on one of these. Any help would be much appreciated.
Steve
07-26-2011 06:41 AM # ADS
07-26-2011, 02:21 PM #2Silver Member
- Join Date
- Jan 2006
- Posts
- 176
Re: Case 580C won't shift
That sounds like basic shifter parts wear or broken parts, such as worn shifter arm, shaft ball, etc. The transmission has to be in neutral between reverse and first for example to be able to shift into second or third. If the shifter is worn or broken, and is not fully returning the transmission layshaft gears to neutral, it won't shift into second or third.
It could be a somewhat minor fix (through the top of the transmission housing with some parts) or something that requires a transmission breakdown, which is a substantial amount of work and expense. Of course, if it is the easy version, you still have to find parts. That are in good shape, which may not be easy for a TLB that is as old as that one ...
07-26-2011, 03:16 PM #3New Member
- Join Date
- Jul 2011
- Posts
- 14
- Tractor
- Case 580C(198?)
It's a good thing I have a mill and a lathe in my shop! Prayin for the easy fix! I'm lookin at gettin this backhoe for a shade more than the price of scrap.
07-26-2011, 03:45 PM #4
Shrek2,
We need a little more information before we can help much.
1) Which "transmission" is the PO saying won't shift? The 4-speed in the floor or the FNR shuttle?
2)If it's the FNR shuttle, are we safe in assuming that it's a mechanical shuttle and not a power shuttle?
There are two diagrams attached below, one shows the mechanical FNR shuttle and linkage, the other shows the 4-speed in the transaxle.
See if you can determine which one's not shifting properly and we can be of more help.
Mark1720 Ford 4x4 w/ 7108 FEL
Case 1845 Uni-Loader NO it's NOT a "C"
190C John Deere
Various implements, some store bought, some home made.
07-26-2011, 05:01 PM #5New Member
- Join Date
- Jul 2011
- Posts
- 14
- Tractor
- Case 580C(198?)
I'll get some more info tonight hopefully. Thanks Mark!
07-26-2011, 06:39 PM #6New Member
- Join Date
- Jul 2011
- Posts
- 14
- Tractor
- Case 580C(198?)
He said it's the shuttle shift with no clutch and the lever on the column for fwd and rev.
07-28-2011, 06:59 AM #7
Steve,
If it's a power shuttle machine, that leads me to believe that the "tranmission" that won't shift without removing the cover is the 4 speed transmission in the transaxle. The power shuttle doesn't have a cover that can be removed.
Unless.... they're talking about removing the floor board to get to the linkage or something.
The powershuttle isn't intensely complicated. It can be removed without disturbing the engine or transaxle, so it's a relatively easy and not terribly expensive job to overhaul it if it's the problem.
The transaxle is more difficult to get to, but still not too complicated in its design, if that's the problem.
If you get the machine, when you get back and you have questions, I'll be glad to help all I can.
And BTW .... thanks for your service!
190C John Deere
Similar Threads
killed my case 580c
By mattellis2 in forum Parts/RepairsReplies: 23Last Post: 11-01-2010, 07:28 PM -
B 2100 - Bevel Gear Case Oil Leak
By KuboB1200 in forum Kubota Owning/OperatingReplies: 1Last Post: 03-18-2010, 01:02 AM -
Building a gun range, suggestions?
By Tororider in forum Rural LivingReplies: 66Last Post: 02-18-2009, 04:03 AM -
Case 580C steering cylinder help
By rexcramer in forum Construction EquipmentReplies: 4Last Post: 04-22-2006, 11:16 AM -
Case 580c
By fredbear241 in forum Construction EquipmentReplies: 19Last Post: 04-14-2003, 05:25 PM
